Degreasing Fluid
Ed Z1-R
Degreasing Fluid
#1 PostAuthor: Ed Z1-R » Fri Jan 08, 2010 12:29 am
Over the moons i have used Car Plan "TETROCLEAN" engine cleaner and degreaser.
I favour this type as when rinsed off it does not leave a greasy/oily film on components.
Alas i have been informed it is no longer available :cry:
So kiddies the golden question is does anyone know or can advise a similar type that is available on the market :idea:
thanx in advance :wink:
:ed
mick znone
#2 PostAuthor: mick znone » Fri Jan 08, 2010 7:54 am
zedrider
#3 PostAuthor: zedrider » Fri Jan 08, 2010 8:02 pm
along side the gunk range used to be a great on called jizer that worked well and washed away clean . hope that helps
zed
Magnum1
#4 PostAuthor: Magnum1 » Fri Jan 08, 2010 9:25 pm
Watch out for the Gunk super strength, it's lethal.
Rod
Never heard of a Harris Magnum
#5 PostAuthor: Ginger Bear » Sat Jan 09, 2010 3:43 pm
Magnum1 wrote:Watch out for the Gunk super strength, it's lethal.
Rod
You're not supposed to drink it! :splat
Ed Z1-R
#6 PostAuthor: Ed Z1-R » Sun Jan 10, 2010 5:58 pm
Thanx chaps will keep that in mind. :wink:
Spoke to the MD of the shop i use to work at he say MORRIS lubricants also do a similar degreaser so will explore ALL avenues
Dude! either im a miser or its £35.00 @5 Ltr :shock:
