Anybody know if the airbox differs greatly between 900 models?
Reason for asking is I'm thinking of reverting back to standard (ie ditching the K&Ns) and I have a Z1b fitted with 900A4 motor, therefore not sure which model airbox to get, or if it actually makes any difference. I presume the carbs are from a 900A4 so would probably be safer the get the A4 airbox and rubbers?
Thanks for any help, Simon.
Airbox spec
- coldsummer
Steve Cooke
- ZedHead
As Ir35 states " the frame is the issue" (May be!).
Both the Z1B and the 900-A4 engines have the same physical dimensions.
Both the Z1B carbs and the A4 carbs have the same physical dimensions, (albeit the Z1b (28mm) the A4 (26mm) .
The difficulty will come fitting an A4 Air-box to the Z1B frame. I'm thinking you may have trouble there. Perhaps not!
Regardz.
PS. if you can get a Z1B air-box make sure it's soft and has not shrunk in dimensions across the carbs holes.
Regardz.
- coldsummer
