THE WIDOW SHAKER............................... What could possibly go wrong?
#31 PostAuthor: Garry.L » Sun Jan 08, 2017 6:55 pm
Test ride didn't go so well then.......
Big Fluff
#32 PostAuthor: Big Fluff » Sun Jan 08, 2017 7:48 pm
Waste of a good engine but a great idea. I reckon a flat 4 would've been a better fit but it wouldn't be a Zed then would it?
#33 PostAuthor: paul doran » Sun Jan 08, 2017 8:34 pm
Garry.L wrote:Test ride didn't go so well then.......
GB don't look too good does He
that ditch did for Him
Z1parR
#34 PostAuthor: Z1parR » Sun Jan 08, 2017 10:03 pm
:rir :rir :rir :rir :brav
0172 . Geoff Parr
#35 PostAuthor: Ginger Bear » Mon Jan 09, 2017 8:12 am
Big Fluff wrote:Waste of a good engine but a great idea. I reckon a flat 4 would've been a better fit but it wouldn't be a Zed then would it?
Will, it would have been a bigger waste leaving this lump in the back of the shed, at least now it will get run & will be removed in an instant should I need a replacement for one of my bikes. :wink:
it's also giving me a great chance to improve my welding skills.... :?? :lol:
#36 PostAuthor: Ginger Bear » Mon Jan 16, 2017 7:28 pm
Bit more progress..............
Made a couple of diagonal rear mounts, mainly to use the rear of the cases as a 'stressed' ( It fookin will be. :?? ) member to stop the chassis rails flexing too much once I get me fat arse on board.
Now this will make the toes of some of you curl..... I took the grinder to the lower 'flange' of the transmission cover. :shock: :shock: You'll see why when you look at the chain run.
The bolt head to the rear of the sprocket is currently fouling the chain. I plan to fit a spacer behind the sprocket & if its still a problem I'll remove it, countersink the case & then a countersunk bolt. :D
PAULJAC47
#37 PostAuthor: PAULJAC47 » Mon Jan 16, 2017 7:33 pm
I like this,if its up to usual Gb standard should go on the club stand,how about some ideas for a name for this Beast? How about the "The Coffin Dodger"??
Redbeard
#38 PostAuthor: Redbeard » Mon Jan 16, 2017 7:52 pm
It's an interesting project, what are the plans for it when it is built? The speed record for one of these is powered by a 600 bandit engine as far as I can tell so this could be a contender for a new record.. :wink:
1979 Z1000ST
#39 PostAuthor: Pigford » Mon Jan 16, 2017 8:07 pm
Fookin' sweet ride :twisted:
#40 PostAuthor: ZedHead » Mon Jan 16, 2017 8:09 pm
Happy to donate a couple of 1.5mm spacers to the cause
#41 PostAuthor: Ginger Bear » Mon Jan 16, 2017 9:05 pm
That's very kind Dave..... I won't say no. :sou
#42 PostAuthor: Garry.L » Mon Jan 16, 2017 9:57 pm
PAULJAC47 wrote:how about some ideas for a name for this Beast? How about the "The Coffin Dodger"??
The Widowshaker
#43 PostAuthor: Ginger Bear » Tue Jan 17, 2017 8:08 pm
'Widowshaker'...... I like that Gary, been chuckling about it all day. :lol: :lol: If nothing else tickles me more in the next few days, then that's it!!
Had another couple of hours to meself earlier. :D
Cut and drilled some 25 x 40mm angle to act as bearing mounts.
Slid the drive sprocket along the splines to clear the screw head & cut the chain to length. I'll probably machine a bit of nylon bar to slide over the gear change shaft, to save it rattling on bare metal. Pulled taught there's around 5mm clearance, but that'll disappear on the 'overrun'
Squared up & clamped bearing mounts to the frame rails ready for welding. Once thats done it'll be time to cut the axle to length & machine some slots to take the drive pins. :??
Gus
#44 PostAuthor: Gus » Tue Jan 17, 2017 10:34 pm
It's gotta have a project name surely?
NEW YORK STREAK
"Set the GRINDER on it"
Hobbo
International Rep
yo
#45 PostAuthor: Hobbo » Tue Jan 17, 2017 10:55 pm
BEAR SHAKER
SCARE BEAR
GINGER NUT 1
PHIL
International Rep
