Spark
jez1100r
#16 PostAuthor: jez1100r » Sat Mar 28, 2015 5:24 pm
Resistance is between your ohm range
#17 PostAuthor: z1bman » Sat Mar 28, 2015 5:50 pm
if it is the pick up coil there will be a big difference in the resistance readings between no 1&4 pick up coil & no 3 & 4. but it could also be the cdi
jez1100r
#18 PostAuthor: jez1100r » Sat Mar 28, 2015 5:57 pm
Only 7 ohms
#19 PostAuthor: z1bman » Sat Mar 28, 2015 10:09 pm
jez1100r wrote:Only 7 ohms
that's way down on what it should be. looks like the problem could be solved :lol: :lol: :lol:
jez1100r
#20 PostAuthor: jez1100r » Sat Mar 28, 2015 10:15 pm
No only 7 ohms difference between 1&4 And 2&3 459 ohm. And 452 ohm
#21 PostAuthor: z1bman » Sat Mar 28, 2015 11:08 pm
jez1100r wrote:No only 7 ohms difference between 1&4 And 2&3 459 ohm. And 452 ohm
pick up coils are in spec so they should be good. next you need to test the cdi
#22 PostAuthor: ZedHead » Sun Mar 29, 2015 10:20 am
no disrespect but have you eliminated other potential causeis? Such as timing, both ignition and valve, and compression. It strikes me that at least one coil, possibly both are generating a spark when you turn it over.
#23 PostAuthor: z1bman » Sun Mar 29, 2015 10:27 am
disconnect the pick up coils from the cdi & see if you still get a spark when you turn on the ignition
jez1100r
#24 PostAuthor: jez1100r » Tue Mar 31, 2015 10:21 am
been at work double sunday & monday .have anther look today
yes there is a spark when i disconnect the pick up coils from the cdi . when i turn on the ignition
#25 PostAuthor: z1bman » Tue Mar 31, 2015 11:17 am
you need to check the resistances on the cdi now which i suspect is shot? what type of cdi has it got? metal with rib's or plastic held in place with a mounting rubber?
jez1100r
#26 PostAuthor: jez1100r » Tue Mar 31, 2015 11:59 am
plastic held in place with rubber mounting
#27 PostAuthor: z1bman » Tue Mar 31, 2015 12:00 pm
i am sure you can use the gpz1100 uni trak cdi
jez1100r
#28 PostAuthor: jez1100r » Tue Mar 31, 2015 12:04 pm
http://www.ebay.co.uk/itm/231470579378? ... EBIDX%3AIT
will have get it off and check numbers
how do you test the resistance on the cdi
#29 PostAuthor: z1bman » Tue Mar 31, 2015 12:06 pm
you need to check in the workshop manual its the same basic test as you have done on the pick up coils but there are more readings to take
http://www.ebay.co.uk/itm/KAWASAKI-GPZ1 ... 19ea008712
jez1100r
#30 PostAuthor: jez1100r » Tue Mar 31, 2015 3:27 pm
had cdi off cleaned all connectors .cant not make any sence of reading i am getting . pluged it all back in now no spark at all .so i have bought the one from ebay and take from there i will let you know how i get on thank you for your help
Users browsing this forum: Bing [Bot] and 58 guests
