Crank case bolt 116mm
jphaynes669
- ZedHead
jphaynes669
- ZedHead
jphaynes669 wrote:If your struggling, make one!. You will need m6 stainless t12 threaded bar, a washer, flush fit nut and a blob of weld.116mm cut from the underside of the nut, clean up the thread where cut..job done!
Cheers JP - but I have been advised not to use stainless as it's not as strong as the originals, and shouldn't be used on crank case halves.
I had thought of buying a pack of these, then using a 4mm washer, or a 2mm washer and and lopping 2mm of the end (would have to check you didn't run out of thread if you start chopping a bolt though), or whatever was needed, but it would be nice to get a proper one if possible.
http://www.ebay.co.uk/itm/M6-X-120mm-Hi ... 259455d9b4
Richard
Somewhere, over a rainbow, weigh a pie.
1976 KZ900
1976 KZ900
jphaynes669
- ZedHead
Richard Q wrote:jphaynes669 wrote:If your struggling, make one!. You will need m6 stainless t12 threaded bar, a washer, flush fit nut and a blob of weld.116mm cut from the underside of the nut, clean up the thread where cut..job done!
I had thought of buying a pack of these, then using a 4mm washer, or a 2mm washer and and lopping 2mm of the end (would have to check you didn't run out of thread if you start chopping a bolt though), or whatever was needed, but it would be nice to get a proper one if possible.![]()
Dont worry richard, the m6 in t12 stainless is more than strong enough, especially at the torque in crank cases etc. Ive used this material in much tougher enviroments than a bike engine. Dont be concerned in the future, but it looks like the members of this club are your saviours. ....
Richard
Jeff.H
