block thread gone
mick znone
block thread gone
#1 PostAuthor: mick znone » Sun Jul 12, 2009 8:19 am
while im putting a new gasket in, i think i will helicoil this thread. the cover is held down with 16 bollts, the rear outside one has been drilled out through the head, a bolt goes through and a nut goes on the end. i believe this can be done in situ, with the tank off, AM I RIGHT GUYS :? its the left hand outside rear thread on the head. the relay guy said it can be done in situ.
Steve Cooke
#2 PostAuthor: Steve Cooke » Sun Jul 12, 2009 8:23 am
No problem in doing that , if you don,t have an M6 Helicoil set I can lend you one with the appropriate Helicoil if you want.
#3 PostAuthor: Ginger Bear » Sun Jul 12, 2009 8:46 am
Mick, just be careful you don't get swarf in & around the cam buckets etc.
mick znone
#4 PostAuthor: mick znone » Sun Jul 12, 2009 8:50 am
great, so it can be done guys. thanks for the offer of the set Steve, but i think i will get someone to do it, im happier fixing houses these days.
wilsonsjw11
#5 PostAuthor: wilsonsjw11 » Sun Jul 12, 2009 9:05 am
Mick.
Glad to hear you meant cam cover gasket.
If you want one PM me your address and I'll send you a new one.
I can send you the M6 Helicoil kit along with the 6,3mm drill bit,it comes with full instructions and really is a piece of piss to fit,simple.
Let me know.
Regards
Steve
Users browsing this forum: No registered users and 85 guests
