hillbilly z1 rebuild
Big Fluff
#31 PostAuthor: Big Fluff » Sun Jun 28, 2009 12:46 pm
hillbilly wrote:and what does that meen :?: i thought they were russ colins pistons,came with 1197 barrels. :?:
Yep, agree with Pigford, those pistons are low comp turbo pistons.
If I were you I would take a look at your compression ratio.
Ideally, you need a CR between 9:1 and 10.5:1.
hillbilly
#32 PostAuthor: hillbilly » Sun Jun 28, 2009 1:13 pm
ive done some studying on the cr rating,and i think with my calculating it shud be about 10.5.1 maybe a bit more.so it might be ok.if not it shunt be a big problem to strip it down and try again with some other pistons.we can do nowt but try eh lads. :wink:
Big Fluff
#33 PostAuthor: Big Fluff » Sun Jun 28, 2009 6:05 pm
hillbilly wrote:ive done some studying on the cr rating,and i think with my calculating it shud be about 10.5.1 maybe a bit more.so it might be ok.if not it shunt be a big problem to strip it down and try again with some other pistons.we can do nowt but try eh lads. :wink:
HB. Best way to calculate your CR:-
Set 1&4 at TDC. Remove plug, fill cylinder with light oil until halfway up the spark plug threads and take note of how many cc's of liquid it took to fill.
If your are then certain of your bore size you can calculate as such:-
In your case.... cylinder capacity (299.25cc) + amount of liquid in cyl (est 32cc) so 299.25 + 32 = 331.25cc.
Then divide this by the amount of liquid, so 331.25 divided by 32 = 10.35. This is your CR i.e. 10.35:1
Regs, Will :wink:
hillbilly
#34 PostAuthor: hillbilly » Sun Jun 28, 2009 6:32 pm
thanks will ,thats just how i did it ,and got about that number,have you been looking at my working out somehow. :lol:
hillbilly
#35 PostAuthor: hillbilly » Sat Jul 04, 2009 4:13 pm
got my bearing races in today
hillbilly
#36 PostAuthor: hillbilly » Fri Jul 17, 2009 8:51 pm
getting it together now.
hillbilly
#37 PostAuthor: hillbilly » Wed Jan 06, 2010 5:20 pm
frame,log book,engine cases ,for sale now. :cry: just so its easier for people to look at. :oops:
hillbilly
#38 PostAuthor: hillbilly » Wed Oct 05, 2011 4:24 pm
deal in progress.maybe see how the next owner does with it.
#39 PostAuthor: Pigford » Wed Oct 05, 2011 4:51 pm
You going for that old XT then Brent :wink:
hillbilly
#40 PostAuthor: hillbilly » Wed Oct 05, 2011 6:08 pm
yep,im after the xt500,got fed up with this one,need sumat for the winter times. :lol: hoping to trade satday,i love the xt,s never had one ont road,so this will be the one for me.ive got an a4 to be on with if i get fed up again.none concours,of course. :evil: got some cams today to give the next engine i build a bit more get up and go.
Users browsing this forum: Bing [Bot] and 82 guests
