i have an old set of carbs , not sure if they are 26mm or 28mm
other than measureing them is there any other thing to check to identify them.
26mm or 28mm carbs ?
- steve bowdler
BunnyZ, as Steve B says, you can tell the early model 28mm by their "flat tops" and the 26mm by their "high tops" at a glance.
However, the Z1R (approx. 1977-8) had a "high tops" 28mm that looks exactly like the 26mm. I don't know how you could tell the difference on these, unless you measure the inside throat. Maybe someone has a clue to distinguish one from the other.
Just to further complicate the issue, the 1974 Z2 (although rare to UK. Europe, US & Aus) initially had "flat-top" 26mm carbs.
I have several sets of 'Z' carbs 26mm and 28mm,And some (With the superior pilot circuit) have fuel enrichener screws on the under side near the float bowl and some have mixture (air) screws on the side. And the only way to tell what venturi size they are other than visual comparison or experience is by going by the part number stamped on the mounting flange or by simply measuring the venturi at the end which goes in to the inlet rubber. Simple ??? .
Have dropped them off , they have 3 screws at top , air screw at bottom of float bowls and most importantly measure 28mm in diameter, also have the open throttle stop screw at side of pulley , which according to manual tells me it is a 1979std 28mm carb,I have a 1977 kz1000, so might explain a bit on the popping exhaust i have....
many thanks for your advice
- steve bowdler
bunnys, I swapped 26mm on my Z900A4 to 28mm off Z1000ST, nearly identical on the outside, the difference in venturi is obvious, first is nearly 27mm the other is nearly 29mm (don't remember exactly) measured easily on the engine side of the carbs, vernier caliper or even a ruler will tell you, as to the jets my 28s were fitted with 15 pilots and 115 mains , not sure if that's stock setup but my bike with custom exhaust was running very lean and was struggling to move on higher revs, I've fitted 17,5 pilots and 120 mains and runs like dream now, with jest is more or less matter of trying different sizes, running the bike and checking the plugs colour if what's fitted is good enough, it's easier if your bike is completely stock.
