Upside down front ends
- z1bnackerkwacker
Purists look away now...You are liable to suffer heart failure..
Anyone out there fitted upside down front end to Z1b ?.
Like to know best/worst for job.Prefer bike to be level or slightly lower without having to drop in yokes.Seen some tall at front, don't like.What are mods/machining needed to yoke/tube/headset,Dimensions, e.t.c...Or is there something out there that will fit ? (doubt it)..Have my eye on R30 White powers..Any one know or can point me in direction of previous thread if it's been discussed, Thanks.
(Edited by z1bnackerkwacker at 7:22 pm on May 23, 2006)
- Rickman CR
- Regular Poster
It might make a good magazine article to report not only on the methods of altering the running gear on your bike but providing an objective view on how this improves the handling. key word being objective or truthfull. Maybe take a lot of honesty particularly if it doesnt do much to the handling characteristics especially if an owner has invested and spent a lot of time on the bike. I'm not saying your bike doesnt benefit from the mod just wondering by how much. Interesting though I'm sure others would agree.
No doubt it would stiffen the front end up but overall does it improve the way it corners? Same for all the various modifications out there.
Mono-shocked Zeds (see pics german link web sites) always seem to lengthen the wheel base which usually results in slower steering I think. Looks impressive parked up but can the altered bike boogie down the owners favourite scratchers course?
Is that a zx9r set of forks and wheels on yours?
- z1bnackerkwacker
- z1bnackerkwacker
- z1bnackerkwacker
- rickman CRR
As the previous 2002 thread from Rob A suggests, too steep an angle and it turns in too quickly and makes for instability problems in a straight line probably. The off set custom yolks seem the best option, if they've been tried and tested. The Streetfighter ethos is good and impressive, but only if the mods work and represents an actual improvement. Otherwise why bother? Still think a wee magazine feature on these types of mods would be a good read. Maybe its been done before? Chris, any views?
- z1bnackerkwacker
All points noted & hoarded, Thanx....Forgot to mention I plan to use Borani/Akront type rims with s/s spokes, so t/disk hub suggestions would be of help, will be scanning sites mentioned already for ideas.Quote: from rickman CRR on 1:11 pm on May 24, 2006
- z1bnackerkwacker
Was your problem whilst fitted to R30 or something else ?...As you probably know Those White Powers have pretty Much every Ajustment possible,(multi, re-bound, compression and pre-load) had mine set quite solid, nothing could live with it through twisties think they should be more than capable with weight, only got rid of it coz of it's appetite for Dragon corsa'(less than 600 miles and my last one was toast) and not the same bike with harder compound,I was more concerned about length, just being lazy, I will get round to looking at right stanchion options, one day....Thanx to everyone keep ideas coming.....P.s....How big, is big John, i'm 12 stone (serious ??)..Quote: from Big John on 6:05 pm on May 24, 2006
If you use the CCM R30 forks they,ll need to be uprated as my R30 dived like the Titanic when I hit the brakes.
Well Gents..... Several points...
Yes... the slow steering wanders a bit... seems to track a bit causing a very mild weaving sensation below 20mph... nothing serious, just mildly annoying until you get used to it, after a weekends riding! The JMC swingarm with the spindle on shortest setting matched with the front end give an identical wheelbase to standard!!! More by chance than judgement. The yokes are set so they drop the forks 50mm but with the 17" wheel the front end is still a tad too low. The setup is good old GSXR 750 kit!!!! Its from a mid 90's bike.... My Gixxer Streetfighter has earlier model USD forks (1990 L model) which are about 50mm longer! I might try them instead to see the difference? The frame has been braced but its still a Zed and weaves in bends a bit 60mph+
The main thing is it looks good.... as a modified Zed!
Users browsing this forum: No registered users and 139 guests
