Carburation problems
Just a quick recap My bike is a Z1B which is totaly standard with the exception of carbs from a Z1R. The problem is the bike has a slight missfire when accelerating at 6000 rpm and a reluctance to rev cleanly please refer to my recent post {first ride update}. At first I thought the problem may be ignition / fuel starvation related however I have fitted the carbs from my brothers Z1B and the bike runs perfectly so on this basis I can rule out all ignition components and fuel tank breather/ starvation.
The carb details are as follows,
Model VM28SS
Mains 115 {standard 107.5}
Piolts 15
Jet Needle 5CN15 3rd position
Fuel delivery rate 1 min 35 secs per litre
Brand new Dyna S, new coils /leads/plugs
Just for extra info the pipes are showing a slight straw colour and the plugs seem ok I am desperate for advice to cure the problem surley the carbs work on the Z1R so should work on a Z1B. Is it a jetting issue ?,too small/too big mains . At 6000 rpm do you switch from pilots to mains and there is a missmatch in jet sizes ? All sugestions welcome don't know what else to do.
Model VM28SS
Piolts 15
I`ll do this from memory but pilot affects 0 - 1/8th opening
Throttle slide cutaway affects 1/8th - 1/4 opening
Emulsion tube and needle 1/4 - 3/4 opening
Main jet 3/4 to full throttle.
There is some overlap between these so some experimentation is required but personally I would try and change settings of what you have before buying other components.
I think a colourtune or Dyno test would help a lot and save money in the long run.
Or buy some Z1B carbs
PaulMceleney
- Chunks
PaulMceleney
- Chunks
The mains are spotlessly clean along with the emulsion tubes [ all items inspected with a jewlers magnifing eyeglass} when you say go standard do you mean standard for the Z1R i.e 107.5 mains or standard Z1B carbs.
Not many suggestions coming forward please guys read the thread and make a suggestion as I am lost without help/ideas.
If you're happy with your carbs.... rubber manifolds..... get it on a DYNO
2nd is suspect ignition/electrix. Hows all electrix.. connections... coils.... over 12volts?
Hows valve clearances...... is head correctly torqued down.
Cracks in cylinder head.... leaky head gasket....
As for jets, the larger slotted & smaller hex are not rated the same. The 'Amal' type (hex) have a higher value and a 150 = about 113 in the slotted jet. So running a 150 Amal will be equivalent to a 115 Slotted
The HEX (Amal) has its fuel flow calibrated in the 'wrong' direction of flow. - ie@ from threaded end to the orifice, & the number is cc of petrol thru jet from clibration direction from a hgt of 500mm. As this is opposite to operational flow, it does NOT correspond to the number stamped on it!!!!
The slotted or button jets are also known as reverse jets, coz the flow is the same from either direction. Therefore the number stamped on it relates directly to the flow - unlike the hex/amal type.
- Geoff Meager
hi
Alan, I have a spare set of z1b carbs available at very reasonable money if you need them?They have not been used for a while but are free moving and not seized. I can send you photos if you wish. I am looking for £70 plus postage. Gez
Gez
PaulMceleney
- Chunks
mark iam using 150 slotted main jets .Alan said his bike was running fine when he used his brothers z1b carbs it was only when he used the z1r carbs that a problem occured . alan you need to get yourself a colourtune and they are easy to use, you don,t need to be a mechanic to use it, there 26 pounds on ebay this will tell you whats wrong with the carbs .Otherwise were all just guessing. Ive spent weekends trying to fix carbs on my own bike waste of time this will tell you the answer in minutes 14mm you need hope this helps
Users browsing this forum: sockpuppet and 117 guests
