Z900 Tail and Z1 Tail
Are the tail fairings for the Z900A4 the same as the Z1s?
Lost in the desert somewhere
PaulMceleney
- Chunks
Big Mac, as Keith says, the Z1 Series ( Z1, Z1A & Z1B) are more rounded at the tail ends... Slightly more rounded to fit more closely around the oval tail-light of the Z1 series. The 900-A4, Z1000 A1 & A2 are squarer to be more in keeping with the squarish tail-lights of these later models.
Both types fit either frames ...... RegardZ
PaulMceleney
- Chunks
PaulMceleney
- Chunks
Big Mac, Not to steal Paul's thunder;
TANKS, The tanks will fit either Z1 series and A4 etc. however, there is a small differents that will be noticed by the experts (that will always find you!). They call the Z1 series tanks "flat bottoms" as the seam is tucked well under the tank more towards the centre. Whereas, the Z900/ Z1000 tanks have the seam more to the outside lower edge.
SIDE-COVERS, You will not fit Z1 series side-covers to the A4/ Z100A1/A2. You may think you can weld the appropriate brackets in a suitable position on the frame..... You get stimmied around the petrol-cock and the seat lock on the LHS. If you get a nice solution to this problem , please let the forum know!
RegardZ
RegardZ
PaulMceleney
- Chunks
- mick znone
other differences in tanks bigmac are, wider nacks on a4 for the wiring harness, hook for strap further forward on a4 and also i think the holes are further apart for the badges on the a4, but i could be wrong on that one
hope this of use. check the beezee's site, that explains it all.
Users browsing this forum: Google [Bot] and 71 guests
