Newbie to Z ownership.
#31 PostAuthor: chrisu » Wed Jan 21, 2009 7:54 pm
dwhitehouse wrote:Here you go then guys.Any idea what this brake master cylinder is off ?
Anyone got a spare lever they want to shift?
That is 100% Suzuki GSXR..............
tlc
#32 PostAuthor: tlc » Wed Jan 21, 2009 7:59 pm
Hey D. You ain`t too far off stock, but also you have a great bike to start modifying to your taste.
Of course you could just ride and enjoy as is :D
Which way you gonna go :?:
#33 PostAuthor: Pigford » Wed Jan 21, 2009 8:03 pm
If you're gonna sell the Suzook brake bit... I may buy it off you :wink:
tlc
#34 PostAuthor: tlc » Wed Jan 21, 2009 8:09 pm
Pigford wrote:If you're gonna sell the Suzook brake bit... I may buy it off you :wink:
As long as you`ll take payment in biscuits :lol:
dwhitehouse
#35 PostAuthor: dwhitehouse » Wed Jan 21, 2009 8:12 pm
tailiftchris wrote:Hey D. You ain`t too far off stock, but also you have a great bike to start modifying to your taste.
Plan currently is to ride it as is over the summer and then maybe I'll look at work I can do over the Winter.
I love the way it looks at the moment to be honest but if I need to replace stuff I think I'll try and restore the originally of the bike as much as poss.
The forks are bugging me. Why if they are original would they have been turned round :roll: I had a quick look at them tonight and can't see any reason why they couldn't be swapped back.
dwhitehouse
#36 PostAuthor: dwhitehouse » Wed Jan 21, 2009 8:16 pm
I've had a scan through eBay and it looks like a H**** lever. Like this one...
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=200275276256
LOL - I guess H**** is a swear word on here :D
Steve R
#37 PostAuthor: Steve R » Wed Jan 21, 2009 8:21 pm
From the z1000 a2 the calipers were moved to the back, supposedly to reduce the stearing momentum or some such.
https://www.z-power.co.uk/merchantmanag ... php?pId=21
Lots of people swapped the earlier ones as this looked more modern!
As far as I know its simply a matter of swapping the forks round to move them back to the front, eay job and no money involved!! :lol:
My Z1A has Z1000 a2 forks on with the calipers at the front.
tlc
#38 PostAuthor: tlc » Wed Jan 21, 2009 8:24 pm
There is an issue regarding the positioning of calipers due to unsprung weight and steering axis.
Personally I prefer to keep things as intended.
Your forks are definately turned. The drain screws are supposed to be at the lowest point.
dwhitehouse
#39 PostAuthor: dwhitehouse » Wed Jan 21, 2009 8:28 pm
Steve R wrote:From the z1000 a2 the calipers were moved to the back, supposedly to reduce the stearing momentum or some such.
Ah, I see. looking at the frame and engine number mine is an def' an A1. So someone has probably swapped them round. This could be my first project before spring ;)
Steve R
#40 PostAuthor: Steve R » Thu Jan 22, 2009 9:09 am
Swapping the forks is easy, you will probably need to loosen the banjos to adjust the brake hoses and that means you will have to bleed the brakes.
Since its a new bike to oyu its probably a good idea to change the fluid any way, but be warned they can be a bitch and a half to bleed, search the site for tips. I use 2 of those little tubes with a one way valve on from Halfords, but its still a nightmare getting all the air out. :cry:
If you are going to look for a standard master cylinder then be aware that there are different types for twin and sinfle discs and they look very similar but the bore size is different.
dwhitehouse
#41 PostAuthor: dwhitehouse » Thu Jan 22, 2009 9:24 am
Steve R wrote:Swapping the forks is easy, you will probably need to loosen the banjos to adjust the brake hoses and that means you will have to bleed the brakes.
Cheers for the tips Steve.
#42 PostAuthor: Rich » Thu Jan 22, 2009 7:54 pm
Looks like a H**** lever to me too.
dwhitehouse
#43 PostAuthor: dwhitehouse » Thu Jan 22, 2009 8:12 pm
Yep it was a H**** lever. I got one today and it fits fine.
Thanks for all your help chaps.
Users browsing this forum: moizeau and 104 guests
