Which engine is this
foreverinthegarage
#1 PostAuthor: foreverinthegarage » Mon Jan 19, 2009 11:22 pm
Hi all,Can any one help me identify the engine i have here, it came to me with no casings and no altinator. I have fitted standard casings from a Z1000 A1 inc the rocker cover with no problem, the problems started when trying to find a rotor nothing from the early engines fits.
When it came to me it had square rocker tops. The engine number is KZTOOAE 076842 which is a later number and if it helps i think its from the USA. And its chain drive
Many Thanks Mick
Z1000 The King Is Still Alive.
#2 PostAuthor: paul doran » Mon Jan 19, 2009 11:43 pm
it's a MK2 motor
the crank has a different taper and the 900 rotor won't fit
the alternator is also different as is the outer casing
foreverinthegarage
#3 PostAuthor: foreverinthegarage » Tue Jan 20, 2009 10:42 pm
Thanks Paul, now i can start to look for the parts i need to complete the motor.
AL MARSHALL
rotor
#4 PostAuthor: AL MARSHALL » Wed Jan 21, 2009 8:32 am
hi foreverinthe garage , i have a rotor from a z1000st which i think is the one you want. i need a 900 type rotor....wanna swop? regards al
trouble.......seek and ye shall find
www.z-clocks.co.uk
#5 PostAuthor: paul doran » Thu Jan 22, 2009 12:01 am
Al I can help
foreverinthegarage
#6 PostAuthor: foreverinthegarage » Thu Jan 22, 2009 12:29 am
Thanks Al But i think i have a rotor now, the bits i still need are the engine case and the windings.
Many thanks for your reply, Mick
AL MARSHALL
roror
#7 PostAuthor: AL MARSHALL » Thu Jan 22, 2009 8:42 am
cheers paul, you have pm
www.z-clocks.co.uk
Users browsing this forum: No registered users and 96 guests
