Hi all, am new to the forum, ain't t'interweb great.
I need advice as I need to put new rubber on my LTD B4 restoration.
The rear tyre that came off the bike was a tubeless type (there was no tyre on the front wheel) but advice from Mr Marsden is that this bike should run tubes. The rear alloy is date stamped 10/79.
What do you guys think, what have you experienced?
On a search for this subject someone mentions that the alloy wheel needs to be marked tubeless, if it isn't then a tube should be used..... whadayafink?
Whilst on the subject, I was going to fit Dunlop GT501 but many here seem to favour Bridgestone BT45. All advice welcome.
If this is a worn out subject, then please excuse me as a newbie and point me in the right direction.
Tyres advice needed for '80 KZ1000 LTD
LTD Project
KZ1000 B4 under light restoration.
- london calling
- Dark Skies
LTD Project
- Dark Skies
LTD Project wrote:So what do you suggest if I need to fit tubes?
Good question. There are very few tubed tyres out there now that fit our bikes. I felt your pain until quite recently because my CSR has spoked wheels. I decided to side-step the issue (and hassle) of fitting tubes by buying tubeless wheels off a later model. Perhaps you could do the same -I bought some secondhand Z1000 J wheels for not much money - they're commonly available.
KZ1000-M1 CSR
LTD Project
Thanks Dark Skies
A reasonable suggestion but unfortunately the LTD has a 16" rear, which I don't think a J model would cater for.... me thinks another call to Mr Marsden is required to get to the bottom of this one.
Thanks to all other responses too
- Dark Skies
LTD Project wrote:Thanks Dark Skies
So does the CSR. However, I found with the wider tyre options available to me it was possible to get a lower profile tyre for the 18" rear over the 16" CSR standard. Once fitted there was only about an inch difference - half an inch either side of the axle and so not very noticeable.
If that doesn't float your boat - the K1 Ltd (1981/82) uses a 16" tubeless cast rear wheel.
KZ1000-M1 CSR
Users browsing this forum: Bing [Bot] and 69 guests
