Z1000R and Z1000J Project - Oven baked paint - carbonfiber
RoyNorway
#151 PostAuthor: RoyNorway » Mon Jun 23, 2008 7:28 pm
Done some today as well; :lol:
The forks are painted with POR-15 paint, seems like a god paint after what I been told. Used airbrush.
Thread lock for the bolts for the brake discs.
Just need to polishing the discs now. :lol:
Starting to look like a bike again now. :roll:
Z1000J 82 model, and Z1000R 83 model, And The Calfshit-GPZ1100-
#152 PostAuthor: Pigford » Mon Jun 23, 2008 8:10 pm
Roy, you did the right thing sticking with the GOLD :twisted:
ollie
#153 PostAuthor: ollie » Mon Jun 23, 2008 9:48 pm
WOW looking great Roy ,cant wait to see the motor in there,thats gonna be one cool looking sickle :vcool :vcool :jake :vcool :jake :xbou
RoyNorway
#154 PostAuthor: RoyNorway » Sun Jun 29, 2008 10:08 am
Thank you boys! :lol: :lol:
Yesterday I painted the head and some other parts.
And after that I throw on the barrel.
Putting two pistons in before I start on installing, and the two others after, that means that everything goes slow and controlled.
And working on the engine like this, so the weight of the barrel dont make any problems for me working alone on it.
So, it goes slowly ahead, and also I am waiting for these little fellow:
Bought brand new on ebay, from orientexpressracing.
310 Dollar. :lol:
Its the old K series from Kerker, where Kerker says that the K stands for kick...haha.
The only thing is that the muffler should be gold...not silver, but I have to wait and see...
:yay
Padders
#155 PostAuthor: Padders » Sun Jun 29, 2008 10:50 am
Looking good :D
Davy Doherty
#156 PostAuthor: Davy Doherty » Sun Jun 29, 2008 5:51 pm
Paitents seems to be the key here! it's looking great Roy.
ollie
#157 PostAuthor: ollie » Tue Jul 01, 2008 9:26 pm
i think davys right ,this project is really paying off ,excellent roy
:kewl :xbo
RoyNorway
#158 PostAuthor: RoyNorway » Thu Jul 17, 2008 10:16 pm
Thank you boys!!!
This is become a long term project, I just have to realize it. :twisted:
But that does not matter, as long as it is fun. :lol: :lol:
After receiving help from members here, I got hold on a TL 1000R swingarm.
The plan was first to use the Hayabusa arm, but after advice from big green bus I bought a TL1000R swing instead.
Here is Busa at left.
Busa arm is 63.5 cm, TL1000R is 59 cm. Approximately total length.
Busa arm on the bike.
No need for grinding, fits straight on without touching anything.
BUT!
The Hayabusa swingarm is not made in center from the Suzuki factory, that means that when you put in a straight frame, the rear wheel will be off center, much. At least minimum 20mm.
The bracing is originally on the upperside on the Busa, since I will use twin shocks it need to go on the underside.
Up side down on the bike.
On the TL1000R the bracing is originally on the underside.
That makes things easier.
Since the Busa arm is not in line you need to cut of some off the aluminium on the pivot, left side.
I chopped off 6mm, but its more left to take.
This is for to move the swing to left,in order to have the rearwheel in line.
My now retired Makita wood saw makes nice cuts on aluminium. :P
After cutting, now the wheel is 10mm out of center.
With Busa swing.
I will not use the Busa swing.
So, it is very easy to convert the pivot bearings on these Suzuki arms to fit the original 16mm kawa pivotbolt.
On the left side it is the originally Kawa swingarm sleeve, 25 mm in diameter outside.
That fits straight in the Suzuki swingarm sleeve. Using 25mm pivot bolt size. :lol:
Here is the swing I will use, TL1000R.
To make the TL1000R arm to fit on this frame you need to grind off about 4-6mm on each side of the "ears" on the frame.
And just mount it up, and its straight in line. :twisted:
And here we are.
I will sandblast and Gun-Kote the swing, GOLD!
:twisted:
Dark Skies
#159 PostAuthor: Dark Skies » Thu Jul 17, 2008 10:21 pm
Looking very sweet indeed, Roy.
KZ1000-M1 CSR
RoyNorway
#160 PostAuthor: RoyNorway » Thu Jul 17, 2008 10:33 pm
Thanks mate. :lol:
davejames
#161 PostAuthor: davejames » Fri Jul 18, 2008 12:01 am
Nice to see the progress Roy, great pics and explanation on fitting swinging arms. Keep it coming :D :D
ollie
#162 PostAuthor: ollie » Fri Jul 18, 2008 12:22 am
Roy ,like the detail about the swingarms ,don't forget about your shock mounts before you paint ,thats one hell of a lump of rubber you have on the rear wheel ,its really looking good
well done :more :brav
ollie :wink:
Steve Cooke
#163 PostAuthor: Steve Cooke » Fri Jul 18, 2008 6:20 am
Excellent job Roy, keep up the good work in documenting it.
RALPHARAMA
#164 PostAuthor: RALPHARAMA » Fri Jul 18, 2008 7:05 am
A fascinating project Roy. I'm really enjoying watching it grow. Keep up the good work :D
Ralph Ferrand
Padders
#165 PostAuthor: Padders » Fri Jul 18, 2008 8:06 am
Very informative Roy keep it coming.
