Z1r wheel spacer
Z1r wheel spacer
Wanted rear wheel spacer for a z1r its the one at the caliper braket 36mm.tia
Re: Z1r wheel spacer
Is this not sorted ?
On 26th May you wrote "all the other parts from the original wheels fitted"
Re: Z1r sprocket carrier
#14 Tue May 14, 2024 6:08 pm
Dk will have all the parts you need.i used z1r wheels,just needed to change the sprocket carrier,all the other parts from original wheels fitted without modification.
Yea all the parts fit,but because of mag wheel the spacer needs to be 36mm instead of standard 31mm.only found out after fitting wheel and caliper rubbing on the disc.like everything its a learning curve.
Keith
mistaken.
Phil Churchett winner 2013
mistaken.
All sorted,thanks cheers Keith for the links
