Z1000 A1 Left Hand Switchgear
GBZ1000
#1 PostAuthor: GBZ1000 » Mon Jun 10, 2024 3:54 pm
Hello all.
I'm looking for suggestions to source a new or refurbished left hand switchgear for my Z1000 A1. My switch has both a hazard switch and a headlamp flash rocker button (see picture), but the only ones I can find new have either the flasher, or the hazard switch, but not both. The alternative would be to have mine refurbished.
Any suggestions you might have to source a new one, or recommendations to get mine refurbished would be welcomed.
Graham
Re: Z1000 A1 Left Hand Switchgear
#2 PostAuthor: Philippe » Tue Jun 11, 2024 4:34 am
Hi Graham
the switch of a Z1000ST is the same if the electricity wires don't run inside the handlebar of your bike.
If they do run inside the handlebar you'll have a gap at the bottom right hand side of the lower half of the switch shell but the connections inside are the same if you have a "european" bike. The switch of a Z1000ST doesn't have the single bullet connectors of the Z1000A1/A2.
If you want to refurbish your switch, have a look at the item I've posted some time ago (technical) where I refurbish one step by step.
It's a bit of fiddling to get the buttons out but you can do it with a little effort and a lot of caution.
Take care of some switches! The plastic part of the high/low beam has a tendency of breaking at the point where the screw passes through and, as far as I know, you can't buy it seperately.
The wires of the indicator switch and of the hazard switch have a tendency of coming loose but you can solder them back on.
Even the horn/pass button can be disassembled but there are a lot of small parts involved.
Good luck!
GBZ1000
#3 PostAuthor: GBZ1000 » Tue Jun 11, 2024 8:41 am
That’s fantastic feedback. Many thanks :D
Graham
#4 PostAuthor: ADRIAN H » Tue Jun 11, 2024 8:52 am
Zpower sell them - https://www.z-power.co.uk/switch-left-side-z1000a1a2
I am pretty sure the Hazard light was only standard on thw american Z1000 Ltd models ?
GBZ1000
#5 PostAuthor: GBZ1000 » Tue Jun 11, 2024 11:42 am
Thanks Adrian.
The bike is a UK model, but it’s possible that somebody has installed the wrong switch earlier in its life.
Graham
Kev1R
#6 PostAuthor: Kev1R » Tue Jun 11, 2024 1:30 pm
The wiring diagram for A1 European model shows both hazard and passing button
US / Canadian only shows hazard switch only
A2's are the same.
Maybe they fitted whatever came to hand.
010
KevinH
#7 PostAuthor: KevinH » Tue Jun 11, 2024 6:59 pm
Uk spec Z1000A1 came standard with left hand hazard switch.
gray
#8 PostAuthor: gray » Mon Jun 17, 2024 8:28 pm
I'll look and see if I have one - I think I do.
Classic Motorcycle Mechanics did an article some time ago on refurbishing your own switchgear - cue frantic scrabbling through "The Archive" - looks like it was June and July 2023 issues
gray
#9 PostAuthor: deka » Wed Jun 19, 2024 9:27 am
Here is the link to Philippe's switchgear rebuild
viewtopic.php?f=22&t=48305&p=400578&hilit=switch#p400578
GBZ1000
#10 PostAuthor: GBZ1000 » Thu Jul 04, 2024 7:51 am
gray wrote:I'll look and see if I have one - I think I do.
Thanks Gray.
Graham
GBZ1000
#11 PostAuthor: GBZ1000 » Thu Jul 04, 2024 7:51 am
deka wrote:Here is the link to Philippe's switchgear rebuild
Thanks Deka.
Graham
gray
#12 PostAuthor: gray » Fri Jul 05, 2024 6:23 pm
I do have one but it's tattier looking than yours - the hazard button is more faded
gray
GBZ1000
#13 PostAuthor: GBZ1000 » Mon Jul 08, 2024 9:04 am
gray wrote:I do have one but it's tattier looking than yours - the hazard button is more faded
Thanks Gray. I’ve replaced it with one without the hazard flasher.
Graham
