I need to remove the fuel tap from my A4 tank and blank the threaded entry off to clean and treat the tank internally and from what I've found, I believe that the thread for the fuel tap is 22mmx1.0mm? Struggling to get anything like this - could always use a tapered rubber bung but I wondered if anyone else has had a previous (better) solution?
Cheers in advance for any help
Fuel Tap Blanking Cap
- bulldogbobby
Re: Fuel Tap Blanking Bolt
i used a tapered rubber bung to block it up temporarily
"Set the GRINDER on it"
Rubber bung is the best method.
An old fuel tap in the off position works a treat
- bulldogbobby
Re: Fuel Tap Blanking Cap
Thanks as always for all the help and thanks Gus - Cap on order
Users browsing this forum: No registered users and 123 guests
