Front part of brake caliper marked B for Z1B
Anyone got a spare Front part of brake caliper marked B for Z1B my bleed nipple has snapped off and isn’t coming out
- Z1streetfighter71
- ZedHead
Re: Front part of brake caliper marked B for Z1B
As a fix for the one you have, a left handed drill bit normally does the trick, heat the caliper up oven/torch first. If you do get a new caliper ill buy the one you have off you if you want to sell it on.
Only need the front half nipple will not come out and now and has part of an easy out snapped in it
- Z1streetfighter71
- ZedHead
shaggy wrote:Only need the front half nipple will not come out and now and has part of an easy out snapped in it
ouch...
Hi.
Snapped easy outs can be removed with the correct tooling though not easy. I've done it on aircraft fasteners where there's no other option for disassembly.
Now got an engineering company going to sort it for me
- paul doran
Easy outs are never a quick fix I find they snap too easily
All fixed by Count engineering in Doncaster
