Correct cam positions for top end re-build.
phil1r
#1 PostAuthor: phil1r » Fri Nov 03, 2023 11:25 pm
Hi folks, just about to put my cams back in after a top end re-build. inlet cam is obvious with the number 28 in a vertical position. But the exhaust cam !!! I have the Clymer manual and it's not a lot of help :!: :!: it looks to me this could be put in 180 degrees out :?:
I'm sure when it took it apart it was at TDC on 1 and 4 and the notches on the cam ends were facing in a particular position.
If anyone can confirm that would be great. or a picture may help.
Thanks in advance.
Re: Correct cam positions for top end re-build.
#2 PostAuthor: zed1015 » Sat Nov 04, 2023 12:15 am
Hopefully this pic will be self explanatory.
Number "5" indicates the timing arrow stamped on the exhaust cam sprocket which should be level ( or very close depending on deck height etc ) with the gasket surface.
phil1r
#3 PostAuthor: phil1r » Sun Nov 05, 2023 7:55 pm
Many thanks Z1015 , Christ I had to use a magnifying glass to find this little mark. Almost hiding behind the rubber damper on the cam sprocket. I did forget to mention, this is for a Z1R. don't suppose its any different. :)
gray
#4 PostAuthor: gray » Sun Nov 05, 2023 8:20 pm
remember that when you're counting pins to 28, the mark on the exhaust cam is pointing to pin ZERO not "1" . The diagram is clear but its easy to forget when you're getting down to doing it.
gray
#5 PostAuthor: zed1015 » Sun Nov 05, 2023 8:30 pm
phil1r wrote:Many thanks Z1015 , Christ I had to use a magnifying glass to find this little mark. Almost hiding behind the rubber damper on the cam sprocket. I did forget to mention, this is for a Z1R. don't suppose its any different. :)
No different.
All the kickstart engines are basically the same Z1 motor.
phil1r
#6 PostAuthor: phil1r » Sun Nov 05, 2023 8:31 pm
many thanks Gray
Users browsing this forum: zed9 and 68 guests
