Due to a change in circumstances the Small shim swapping service has been passed over to myself, available are the smaller 13mm shims, fitted to Z650's 750's GPz1100 Uni-Trak & the 1100R
I am happy to run the swap service for these smaller shims but you will still need to Contact Jerry for the larger ones . I propose to run it the same way as Steve ( GB) did like so :-
Initial contact request by PM will ensure you get my home address, and at the same time it would be a good Idea to let me know what you want as at present the stock is not exhaustive :-
Send your old shims to me, in a Jiffy bag or something capable of holding them safe, just take note that if they are loose in an envelope or similar then there is a strong possibility that the post office sorting rollers will make short work of displacing them and I cannot be held responsible for this.
Also, in the bag along with the shims to be swapped there will need to be a return address label, and a large letter stamp (very Important) and a note saying what size replacements you need, plus your membership number. I will then send you back the required shims as quickly as possible. Please be advised if any of the above criteria is missing, it will not work.
This service will be free to paid up club members , I will check.
It will also be offered to forum only members, but will require a 'donation' of £1.00 per shim swapped. All donations will go to the club’s charity fund for dispersal at the appropriate time .
13mm Under Bucket Shim Swap Shop. Now Under New Management…. Again.
Keith
mistaken.
Phil Churchett winner 2013
mistaken.
- new poster
Re: 13mm Under Bucket Shim Swap Shop. Now Under New Management…. Again.
Hi
Who do i contact for shim swap for Z900 shims
Phil Hall
Phil Hall
PM Jerry President of the club who you will find at the top of the members list
Zeds-R-Us
- Regular Poster
Hello I need a shim for a Z1B (larger type) about 1.9mm, do you have one I could swap please?
Regards
Stinky
Regards
Stinky
Stinkfinger wrote:Hello I need a shim for a Z1B (larger type) about 1.9mm, do you have one I could swap please?
Regards
Stinky
The thinnest stock shim is a 2.0 mm ( although i have had a 1.9mm from a different source but i wouldn't use one.)
If you are down to the thinnest shim you need the head off and trim the valve stems etc and even the collets and retainers to regain some clearance.
- Regular Poster
Hi is that because the shim may bend as its only 1.9mm thick?
