chain & sprocket kits, what's best ?
neil.p
#1 PostAuthor: neil.p » Tue Apr 29, 2008 11:46 am
Digging the trusty Z out for a spin down to the Ace I noticed that the rear chain has got a split link in it. It's probably a legacy of some lazy bugger not wanting to do the job properly, I want to replace the chain and reckon I may as well replace the sprockets at the same time. What do you guys recommend
chain wise ? Thanx for the help, regards Neil.P
RALPHARAMA
#2 PostAuthor: RALPHARAMA » Tue Apr 29, 2008 2:15 pm
I think you have to go a long way to beat DID. I think Z Power do 'em
Ralph Ferrand
phil churchett
#3 PostAuthor: phil churchett » Tue Apr 29, 2008 3:51 pm
I try to use DID too,if not another good make of chain.
Don't use cheap chain, it's crap!
neil.p
#4 PostAuthor: neil.p » Tue Apr 29, 2008 3:59 pm
Ok, DID sounds like the one to have, I take it there is no problem fitting an 'O' ring chain ? Seen X ring chain talked about but must admit to not having a clue what it is, thats kind of a legacy of having British stuff I guess.
Thanks for your input so far, regards Neil.
phil churchett
#5 PostAuthor: phil churchett » Tue Apr 29, 2008 5:40 pm
Neil, for more info on "O" and "X" ring chain, take a look at www.didchain.com
classkawa
#6 PostAuthor: classkawa » Tue Apr 29, 2008 7:07 pm
If you are still running a 630 how about considering the change to 530. B & C do a conversion that includes the spacer for the front sprocket.
The 530 are easily up to it. I have only adjusted mine twice in 3,000 miles and found benefits such as better gear change and less noise. Chain brand is Tsubaki X ring by the way.
Steady Eddie #21
Users browsing this forum: skinnyZED and 42 guests
