Tool tray decal 73 Z1 900
Hi does anyone know were or if you can buy the tool tray decal the one that says model z1 & does not have the clock stop light on the diagram, or a original one would be better,
Re: Tool tray decal 73 Z1 900
marmck wrote:Hi does anyone know were or if you can buy the tool tray decal the one that says model z1 & does not have the clock stop light on the diagram, or a original one would be better,
By "tool tray" do you mean the Document Tray in the ducktail?
You could drop a mail to John Clifton in Oz at;
donjohn214@gmail.com
He produces Zed decals using a photographic process from originals and they are spot on (he's recommended by John Brookes). I got a set from him and they're brilliant. Unfortunately I can't speak for the Document Tray decal as I still had my original tray with the original decal attached so didn't require one. Good luck.
Z1-B, 360bhp ZX1000NGF
Yes it is the doc tray, thanks for the reply
I assume you mean the one used from approx Z1F02000-Z1F20000
I am not aware of anyone doing the 4.2 qt label without the outage switch info. Only the 3.7 qt without is available. I'm surprised no one has ever done this decal as it applies to about 18000 Z1's
Yes John the decal between 2200 & 20000.I read in your book that you didn't know of anyone making these ,just thought someone might of started doing them since your book was published,as you say a lot of bikes not covered,thanks Martin
John Kenworthy of Sunrise Graphics might have done some. He is always at the Stafford shows.
John in Oz does`nt make doc tray decals ,have e-mailed john in UK awaiting reply ,will keep you updated ,Thanks for the replies
If somebody sends me a pic with dimensions I can easily make some no problem.
PM me with info, I'm in the Isle of Man till next Wednesday though.
Dimensions of my Z1a repro decal is 163mm high x 142 width ,could you check Z2John please if you have a original Ta ,& a pic,not the best pic ,will ask Z2john if he has a better one Thanks Martin
Thanks. Yes a better pic is needed but supply won't be a problem.
Will
Will
John kenworthy has retired , Z2John you have pm , anyone else require one of these decals
Can some kind soul with a original doc decal the same as posted above,send Bigfluff a descent pic & sizes of the decal ,thanks in advance ,cheers Martin
Managed to find a original one at a reasonable price, hopefully it will clean up well !
marmck wrote:Managed to find a original one at a reasonable price, hopefully it will clean up well !
Please send me a copy so I can produce for other members.
Big Fluff wrote:marmck wrote:Managed to find a original one at a reasonable price, hopefully it will clean up well !
Will Do
