650b2 carb issue
650b2 carb issue
Hi guys, I have an annoying stutter from closed throttle to opening it up, soon goes but annoying, carbs stripped and blown through, and cleaned, notch 3 on needles, all stock jets and air box, only thing not stock is the patten silencers, could it be I need to change the pilots? Tia.
Re: 650b2 carb issue
DavidZ1R wrote: notch 3 on needles Tia.
The needle position is wrong .
On the 650 it should to be 4th from the top so it needs lifting a notch.
Also have you had your choke plunger seats done ?
zed1015 wrote:DavidZ1R wrote: notch 3 on needles Tia.
Yes you did the plungers, I thought the manual said 3rd notch, will double check, cheers
similar prob for me earlier this summer cured by replacing the advancer unit springs - they had stretched and so when you opened the throttle a bit, it went to full advance straightaway.
gray
Yes the ignition was next up for me, I replaced the carb boots yesterday just in case, just the same, that's easier than taking the bloody carbs off again.
