900 rear wheel spacer dims
RALPHARAMA
#1 PostAuthor: RALPHARAMA » Fri Jun 03, 2022 2:25 pm
Anyone able to tell me the dimensions of the spacer that goes between the sprocket carrier and the inside of the swinging arm on an A4?
Can’t find one so need to make one .
cheers
Ralph Ferrand
Re: 900 rear wheel spacer dims
#2 PostAuthor: warren3200gt » Sat Jun 04, 2022 5:05 am
Assuming they have stock. Alternatively measure internal and external dims from carrier and axel. Width is 11mm.
https://www.z-power.co.uk/rear-axle-col ... 977---1981
CAT3
#3 PostAuthor: CAT3 » Sun Jun 05, 2022 10:37 am
A lot of seals have their dimensions printed on the outside face in a series of a group of three numbers. You might be able to read the seal dimensions, which would give you the outside diameter too.
RALPHARAMA
#4 PostAuthor: RALPHARAMA » Sun Jun 05, 2022 1:36 pm
All made and ready to be fitted .... all I have to do now is find what I did with the bag of brand spanking new cush drive rubbers :lol:
It's only a dry build so I can leave the rubbers out for now. They'll come to light when I have bought a new set on the final build :roll:
Ralph Ferrand
Users browsing this forum: stusco and 28 guests
