Low speed handling
Tipster
Low speed handling
#1 PostAuthor: Tipster » Mon May 09, 2022 5:06 am
I have recently bought a restored Z900A4. Very pleased, but it weaves left/right at low speed. Wheels seems fine/straight. Tyres are Avon Roadriders (new) and 42/36. Does anybody have a suggestion?
Re: Low speed handling
#2 PostAuthor: zed1015 » Mon May 09, 2022 7:39 am
Give the bike a good going over and check that the steering bearings are correctly adjusted and that the swingarm and wheel spindles etc are not loose.
Don't trust that whoever restored it put it together correctly and also components bolted to freshly painted or powder coated surfaces can settle and work loose after a few miles running.
#3 PostAuthor: Garry.L » Mon May 09, 2022 10:02 am
As above, and try a little adjustment of the Tyre pressures, factory pressures may not always suit modern rubber on a 50 year old bike.
zapo
#4 PostAuthor: zapo » Mon May 09, 2022 12:03 pm
Also check that front tyre beads have seated correctly.
There is usually a line moulded into the lower sidewall which you can use to judge that the tyre beads are concentric to the wheel rim.
I see Zed people.
King of Kings
#5 PostAuthor: King of Kings » Mon May 09, 2022 1:02 pm
Tyre pressures way to high, try 28/32 :)
#6 PostAuthor: chrisu » Mon May 09, 2022 3:39 pm
i assume you've checked headstock and wheel bearings..........
i'd agree pressures are a little high - i normally run 32 front/36 rear.
Tipster
#7 PostAuthor: Tipster » Fri May 13, 2022 3:46 am
Thank you, every one, for your suggestions. I am taking up all of them today and hope to cure the problem.
Users browsing this forum: FOZ1A and 48 guests
