Replace Ignition Key Switch
Wayne1960
#1 PostAuthor: Wayne1960 » Sat Jul 10, 2021 2:58 am
Hi i have swapped out the steering lock and seat lock from the 3 new items i purchased from Z Power. does anyone have a simple step by step guide for replacing the ignition switch please?
Bike now finished what a joy!
Re: Replace Ignition Key Switch
#2 PostAuthor: Philippe » Sat Jul 10, 2021 12:35 pm
Hi Wayne1960
for what kind of model ? Z1 or Z900A4 ? or Z1000 ?
Wayne1960
#3 PostAuthor: Wayne1960 » Sat Jul 10, 2021 2:15 pm
Hi Philippe i hoped you might answer.
Its a 1976 Z900 A4
#4 PostAuthor: chrisu » Sat Jul 10, 2021 3:14 pm
if you remove or lower the headlight bowl (take off the light unit and remove 1 of the indicator stems. this gets you more room.
remove idiot light cover.
disconnect ign switch
unscrew round black plastic bit from top of switch.
drop switch out from the bottom
refit in reverse.
Wayne1960
#5 PostAuthor: Wayne1960 » Sat Jul 10, 2021 3:30 pm
Perfect thanks
#6 PostAuthor: Philippe » Sat Jul 10, 2021 4:25 pm
Hi Wayne
I was too late to check your answer...
Chris was faster !!!
Just do it as he says, I couldn't do it better.
Wayne1960
#7 PostAuthor: Wayne1960 » Sun Jul 11, 2021 8:57 am
Ok the inevitable happened and the wires in the male plug came out leaving only the white attached!
How do i connect the wires back into the male brass pins!
#8 PostAuthor: chrisu » Sun Jul 11, 2021 11:33 am
new plug with new pins is what i'd do - try vehicle wiring products or bikerstoolbox
Wayne1960
#9 PostAuthor: Wayne1960 » Sat Jul 17, 2021 8:07 am
Ok new plug fitted and all good. well nearly! the neutral light decided to play up and doesn't come on
checked in neutral
checked lamp with new and the lamp is ok
checked the 2 wires brown and red/green and they look ok
is it something simple?
Users browsing this forum: No registered users and 95 guests
