Loom protection question - 1973 Z1
jpward58
#1 PostAuthor: jpward58 » Thu Apr 08, 2021 3:11 pm
Hello again people,
Does anyone know if it is possible to replace / or properly repair the sheathing on the wiring loom where it travels past the headstock area?
Mine is cracked in several places. it's been taped up here and there but I'm really not happy with that kind of bodge to be honest. The wiring is fine (and still original) so I dont want to fully replace it if I can somehow re-protect it.
Any ideas / past experience and know how would be gratefully received.
Many thanks
John
Re: Loom protection question - 1973 Z1
#2 PostAuthor: Philippe » Thu Apr 08, 2021 3:31 pm
Hi John
you are not alone !!! It's normal that the old plastic sleeve deteriorates and that cracks appear.
It's possible to replace the old plastic sleeve with a new one but it takes a lot of fiddling.
You have to remove the multi connectors (don't forget to make notes where which wire goes !!!!), guide the electrical wires through the new plastic sleeve and install them back in the connectors.
You can remove the wires from the connectors by inserting a very small flat screwdriver in the connector and bend the little copper lid that retains each wire. It takes patience, a lot of patience to do that. Once the wires are out of the multi connector you have to bend the little copper lid again before you place it back in the connector so that the wire will stay at its place.
Perhaps other people have better ideas but that's how I replace the plastic sleeve.
Good luck!
MrDavo
#3 PostAuthor: MrDavo » Thu Apr 08, 2021 5:00 pm
I've never tried it (always either replaced the loom or used insulation tape to tidy up), but are there heat shrink sleeves big enough to get the end of loom connectors through, but able to shrink tight enough to do the job?
1974 Z1A
1969 H**** CL450 ‘Scrambler’
2005 H-D XL1200R Sportster
#4 PostAuthor: kev edwards » Fri Apr 09, 2021 6:54 am
On my last XS650 i removed all the connectors naturally making diagrams of where every wire went in the blocks, and used appropriately sized bicycle inner tube instead of PVC sleeving, OK not genuine but a lot more flexible and it works well.
jpward58
#5 PostAuthor: jpward58 » Fri Apr 09, 2021 10:12 am
Thanks Gentlemen,
I'm glad I joined this club. Only a few weeks in and the help has been worth every penny.
Re your answers, thanks again for the positive input.
As the bike is really original in most aspects I would prefer to go down the route of replacing like for like even if it is a pain to do it. They are after all a labour of love!
So it's Phileppe's option that I'd need to follow. This of course brings up more questions is it available? And if so where can I get hold of the sleeving?
Best regards
John
z2.john
#6 PostAuthor: z2.john » Fri Apr 09, 2021 10:44 am
I used to get mine from here
http://vintageconnections.com/Products/ ... g-and-Wrap
There might be UK stockists by now. Be interested to know as shipping and customs is now a right pain from USA
needaz1100r
#7 PostAuthor: needaz1100r » Fri Apr 09, 2021 8:36 pm
z2.john wrote:I used to get mine from here
Vehicle wiring products and, I think 12volt planet do it in the UK.
Mark.
jpward58
#8 PostAuthor: jpward58 » Mon Apr 12, 2021 1:02 pm
Thanks gents
Much appreciated as always
John
DogsbolloxofZ1B
#9 PostAuthor: DogsbolloxofZ1B » Sun Apr 18, 2021 7:10 pm
Done this a few times exactly as described. Make sure you get the hi-gloss version of the sleeving.
jpward58
#10 PostAuthor: jpward58 » Wed Apr 21, 2021 11:01 am
Thanks dogsbollocks will do
Users browsing this forum: LeeJackson, zed9 and 70 guests
