Unknown Disc Identity
#1 PostAuthor: r3sc » Wed Dec 11, 2019 5:43 pm
Hi Guys,
Please see enclosed images of a disc which came on a front wheel that I bought for the hub some time ago.
The hub was fitted with a 5E dated rim.
The disc is 277mm in diameter and measures around 4.65mm thick and has the 4 mounting holes. The holes in the braking surface look like standard Kawasaki drill pattern.
The question is, does anyone know what bike this comes from as I want to put it on eBay as it’s surplus to my needs now.
I’ve cleaned it up a little with scotchbrite and re painted the centre satin black so someone should be able to get some use from it.
Please let me know what it might have been fitted to originally.
Thank You.
Re: Unknown Disc Identity
#2 PostAuthor: warren3200gt » Wed Dec 11, 2019 7:24 pm
Later twin disc 650 would be my guess
#3 PostAuthor: ADRIAN H » Wed Dec 11, 2019 7:42 pm
Probably a 1979 onwards Z650.
Keefleaf
#4 PostAuthor: Keefleaf » Wed Dec 11, 2019 10:41 pm
Front disc,rear disc ?
Rear discs are ‘shallow’ - difficult to tell from image.
#5 PostAuthor: r3sc » Thu Dec 12, 2019 7:59 am
Hi,
I’m not sure if it’s front or rear. It came on a front hub but that doesn’t mean it is a front.
See additional images.
Thanks all for your help.
Keefleaf
#6 PostAuthor: Keefleaf » Thu Dec 12, 2019 7:23 pm
Does look shallow ?
Guess compare with another disc or two .
#7 PostAuthor: Philippe » Sat Dec 14, 2019 4:26 am
Hi r3sc
the disc was produced in the first 4 weeks of 1979. The 4 stands for the year; 1979, the A stands for the first 4 weeks of the year.
It could be a Z1000 MK2 front disc allthough I'm not sure about the diameter.
I 'm not familiar with Z650 parts . As far as I know it looks very much like a front disc because the connecting parts between the centre and the disc itself are "hollow". The connecting parts of the rear discs are not, they're a bit rounded.
#8 PostAuthor: r3sc » Sat Dec 14, 2019 10:39 am
Hello Philippe/All,
Thank you for your input and suggestions. I’m still not certain what it’s for but I’ll see how it goes. I have fitment options now!
Cheers.
#9 PostAuthor: z1bman » Sat Dec 14, 2019 5:46 pm
they are z650 c1-c3 discs. z1000 mk 2 are 296mm diameter
#10 PostAuthor: ADRIAN H » Sat Dec 14, 2019 9:49 pm
z1bman wrote:they are z650 c1-c3 discs. z1000 mk 2 are 296mm diameter
+1
Sgt.Pinback
#11 PostAuthor: Sgt.Pinback » Sat Dec 14, 2019 11:02 pm
+2
Cheers, Uli
#12 PostAuthor: r3sc » Sun Dec 15, 2019 9:09 am
Thanks guys,
Looking more conclusive now!
Users browsing this forum: No registered users and 76 guests
