Battery Charger
AlanB
Battery Charger
#1 PostAuthor: AlanB » Mon Aug 26, 2019 5:46 pm
Wanna get a new Trickle/Smart type charger for my Yuasa Acid filled Battery - Which one would you recommend ? Cheers guys :blah
janluke
Re: Battery Charger
#2 PostAuthor: janluke » Mon Aug 26, 2019 7:38 pm
I've had a couple of Oxford ones for over 4 years and they both work well, quite keenly priced too compared with the established brands
Re: Battery Charger
#3 PostAuthor: zed1015 » Mon Aug 26, 2019 7:47 pm
I use Optimates 4's for my acid and gel batteries.
Never had a problem, keeps them maintained over winter and does a good job of recovering batteries that are so deeply discharged you would normally chuck in the bin.
AlanB
Re: Battery Charger
#4 PostAuthor: AlanB » Mon Aug 26, 2019 9:42 pm
Thanks guys - Been looking at the CTEC XS 0.8 at about £60 so anyone used one of these ?
zince
Re: Battery Charger
#5 PostAuthor: zince » Mon Aug 26, 2019 10:17 pm
Hi Alan
I use the CTEK chargers on several bikes and they have always been reliable and well made . I might just suggest that you go for the larger 5A one as its on offer at 60.00 at the moment on Amazon and might be useful to use on other vehicles if you ever need to use it elsewhere with a higher power requirement (larger cars, boats etc etc ) ..
Good luck
Vince
HD/GS/Z1/Z900RS/ Norton
AlanB
Re: Battery Charger
#6 PostAuthor: AlanB » Mon Aug 26, 2019 10:48 pm
Thanks Vince although I see the smaller 0.8 one is on offer at £36 at Halfords of all places !!
Re: Battery Charger
#7 PostAuthor: ADRIAN H » Tue Aug 27, 2019 7:58 pm
AlanB wrote:Thanks guys - Been looking at the CTEC XS 0.8 at about £60 so anyone used one of these ?
Have had two of these for last couple of years. They work a treat very pleased with them.
johny brando
Re: Battery Charger
#8 PostAuthor: johny brando » Tue Aug 27, 2019 11:23 pm
Hi Alan , I bought a new CTEK- MXS 5.0 4.5 years ago so I can only comment on that model........ but it's been outstanding ! I use on it religiously on both my lead sealed & unsealed & sealed AGM batteries too , I maintenance cycle/charge each one every month & once a year I run the 'Recondition Cycle' on each of them. I have 9 various bike batteries & ( some are now actually 9 years old & all of them are still going strong ) There not a cheap charger... but they are typical Scandinavian quality items. I'd certainly recommend them . Cheers, Johny. B.
scott
Junior Section leader
Re: Battery Charger
#9 PostAuthor: scott » Wed Aug 28, 2019 9:27 am
I've used CTEK chargers for years, very good indeed.
AlanB
Re: Battery Charger
#10 PostAuthor: AlanB » Sat Aug 31, 2019 9:51 pm
Thanks all - got the CTEC charger - As a matter of interest, when connecting trickle chargers do you usually connect negative lead to the - battery terminal or to frame of bike ? Also, if you use the eyelets (rather than the clamps) to connect to the battery terminals, can you leave these connected permanently to the battery with the lead and "smart connector" available to use when parked up ? Cheers :blah
scott
Re: Battery Charger
#11 PostAuthor: scott » Sun Sep 01, 2019 7:48 am
Connect to battery terminals. I leave the eyelets and leads connected permanently. Ease of use. Also used the same connector outlet for my sat nav. Just plug in when want to use.
Users browsing this forum: zed9 and 66 guests
