Wanted Cam Caps-Z1or Z900
PJONO
#1 PostAuthor: PJONO » Sat Jun 08, 2019 11:31 am
Hi,
In urgent need of one or more exhaust cam caps. Could get away with just the one numbered one or three. My number one has been installed the wrong way around at sometime and the camshaft is floating. Why I don't know! Now allowing the cam to move over and catch.
Please PM or call on 07511801197
wilsonsjw11
Re: Wanted Cam Caps-Z1or Z900
#2 PostAuthor: wilsonsjw11 » Sat Jun 08, 2019 8:04 pm
I assume you know these items were line bored thus matched to the head.
Regards
Steve
PJONO
#3 PostAuthor: PJONO » Sat Jun 08, 2019 9:10 pm
Hi Steve,
Yes, I appreciate they were, but I've little option other than to adapt one to check the cam end float which is catching. I may try and repair the damaged one.
#4 PostAuthor: Philippe » Sun Jun 09, 2019 4:17 am
Hi PJONO
There are different cam caps in the Z1-Z900 series...they change nearly every year of production. It's very important that you have the correct cam caps so that they align . As stated before by Steve: they were line bored with the head!
You may be lucky finding cam caps that fit your cylinder head but take care.
Have you tried to use new camshaft shells? This might solve your problem.
I hope you find a solution!
PJONO
#5 PostAuthor: PJONO » Sun Jun 09, 2019 6:22 pm
yes I might try new shells. Cant hurt
Users browsing this forum: Yellow and 29 guests
