Re Z1000a1 needles in an Z1000 A2
snowyz9
#1 PostAuthor: snowyz9 » Thu Mar 07, 2019 2:18 pm
Is this a good swop , as the a2 ones are leaner
Re: Re Z1000a1 needles in an Z1000 A2
#2 PostAuthor: Philippe » Fri Mar 08, 2019 3:53 am
Hi Snowy
are you talking about the needle bearings of the swing arm?
They're the same , the only difference is that the A1 swing arm has only place for one on each side and the A2 swing arm has two on each side.
#3 PostAuthor: ADRIAN H » Fri Mar 08, 2019 8:51 am
Carbs ?
snowyz9
#4 PostAuthor: snowyz9 » Fri Mar 08, 2019 2:28 pm
Sorry Guys , il be more specific , Yes carb main jet needles , speaking to z power , Kawasaki no longer sell , and twith the rebuild kits , the main jet needles are not coded,
#5 PostAuthor: warren3200gt » Fri Mar 08, 2019 2:55 pm
Have you tried allens performance. http://www.allensperformance.co.uk/shop/
snowyz9
#6 PostAuthor: snowyz9 » Sat Mar 09, 2019 9:16 am
waiting on e mail , got pilots there
snowyz9
#7 PostAuthor: snowyz9 » Sun Mar 10, 2019 10:38 am
Cybike list 2 different full carb rebuild kits , but dont seem to sell jet needles separate
#8 PostAuthor: Ultim8pc » Mon Mar 11, 2019 8:47 am
I might have a set of new and unused Keyster needles kicking about if that helps.
snowyz9
#9 PostAuthor: snowyz9 » Mon Mar 11, 2019 11:25 pm
Thank you so much ultim , but think I will try to replace with mikunis, was the A2 ,s different jet needles for leaner running ?
#10 PostAuthor: Ultim8pc » Tue Mar 12, 2019 10:08 am
snowyz9 wrote:Thank you so much ultim8 , but think I will try to replace with mikunis, was the A2's different jet needles for leaner running ?
No worries.
Not sure about why, but I would suspect it was all push towards less emissions and thus leaner running...
snowyz9
#11 PostAuthor: snowyz9 » Tue Mar 12, 2019 10:17 am
Thanks Ultim
