Take-off stock.
- Regular Poster
Re: Take-off stock.
Got bellmouths on it,,,,!
- ZedHead
Re: Take-off stock.
Stogmuller wrote:Wouldn’t have an airbox to suit my 1982 Z1000,,,,?
If it's 82, it should be the J model, I don't have one, but they are plentiful (in compaison) on E-Bay.
https://www.ebay.co.uk/itm/Kawasaki-Z10 ... :rk:9:pf:0
Mark.
Mark.
- Regular Poster
Re: Take-off stock.
- ZedHead
Re: Take-off stock.
needaz1100r wrote:ADRIAN H wrote:needaz1100r wrote:ADRIAN H wrote:z1 - Z900 rear hub would be appreciated if at all possible !
Wonga waiting, burning a hole in my pocket.
Please send me a PM.
Have replied to your pm and e-mail. Kind regards Adrian
Have you seen this...
https://www.ebay.com/itm/143115074996
Shipping seems reasonable, import costs are reasonable through the global shipping program.
Mark.
Mark.
Re: Take-off stock.
needaz1100r wrote:needaz1100r wrote:ADRIAN H wrote:needaz1100r wrote:ADRIAN H wrote:z1 - Z900 rear hub would be appreciated if at all possible !
Thanks for this. I had not seen it. Will be bidding on this.
Re: Take-off stock.
Hi I would be interested in a complete starter clutch for a z1000 including damper ring if you have one
thanks David
thanks David
Re: Take-off stock.
What's the swingarm off in the picture I have one similar on the H I think
Re: Take-off stock.
- ZedHead
Re: Take-off stock.
Swirl wrote:What's the swingarm off in the picture I have one similar on the H I think
Identical I think, I am sure it's a Dresda.
Mark.
Mark.
- ZedHead
Re: Take-off stock.
dbee wrote:Hi I would be interested in a complete starter clutch for a z1000 including damper ring if you have one
thanks David
I do, but they have the typical loose centre on the rotor. I'll PM you.
Mark.
Mark.
- ZedHead
Re: Take-off stock.
ADRIAN H wrote:needaz1100r wrote:needaz1100r wrote:ADRIAN H wrote:needaz1100r wrote:ADRIAN H wrote:z1 - Z900 rear hub would be appreciated if at all possible !
Did you win this? If not there is another one...
https://www.ebay.com/itm/Kawasaki-H2-75 ... 3115074996
Mark.
Mark.
Re: Take-off stock.
Hi guys
keep in mind when bidding on a rear wheel hub that the H2 750 two stroke triple rear hub has 6 central holes where the cushion rubbers sit, the Z1/A4 rear wheel hub has 6 holes which are NOT in the middle !
It's a detail because everything else is the same but sometimes details matter.
- ZedHead
Re: Take-off stock.
Philippe wrote:Hi guys
Awesome!
I thought I was an anorak, do you ever go out?
Mark.
Mark.
Re: Take-off stock.
Hi needaz1100r
I thought I was a rivett counter, not an anorak...
Oh I do go out sometimes, almost everyday to go to work, and now and then I work a bit on the restoration of a wreck and I have a ride on one of my bikes and...
Believe me, details are sometimes important. When you buy a rear H2 hub and you don't know that those are different and then you buy cushion rubbers for a Z900 and they don't fit...
Trust me I know what I'm doing...sometimes
Re: Take-off stock.
needaz1100r wrote:ADRIAN H wrote:needaz1100r wrote:needaz1100r wrote:ADRIAN H wrote:needaz1100r wrote:ADRIAN H wrote:z1 - Z900 rear hub would be appreciated if at all possible !
Did did bid on it, but did not win it. I thought some of the bidding was a bit suspicious !
