A few bits'N'peices.
Advertise your BIKES and PARTS here
garyd
#1 PostAuthor: garyd » Sun Oct 21, 2018 5:48 pm
Z1000 caliper and arm £10
Z1000 centre stand £35 has some wear marks but has been coated recently
New PMC gearbox/output shaft bearings. £75 ( These are £155 from ZPower)
Z1000 rear brake levers £7 each
Rear wheel adjusters with Stainless bolts £10
Kiststart £25
GPZ/J type Brake levers FREE...who wants them!
Brake calipers two different types £10 each.
APE set of 7 valve guides ( Handy if you don't need to do them all!) £40
Padders
Re: A few bits'N'peices.
#2 PostAuthor: Padders » Sun Oct 21, 2018 6:35 pm
Can I have the centre stand if still available please Gary
Cheers Ian
PUM 13
garyd
#3 PostAuthor: garyd » Sun Oct 21, 2018 7:17 pm
Centre stand Sold :)
walshyco
#4 PostAuthor: walshyco » Sun Oct 21, 2018 7:20 pm
Hi Gary can I have the two front calipers please. Sean.
Wrigers
#5 PostAuthor: Wrigers » Sun Oct 21, 2018 7:31 pm
I'll take thd bearings. PM sent
#6 PostAuthor: zed1015 » Sun Oct 21, 2018 7:33 pm
I'll take the guides.
Pm Sent.
garyd
#7 PostAuthor: garyd » Sun Oct 21, 2018 9:23 pm
Bearing, guides and calipers sold.
FOZ1A
#8 PostAuthor: FOZ1A » Sun Oct 21, 2018 10:01 pm
Gary, I will take rear Cali per and arm, z1000 rear brake pedal and kickstart.
Foz
garyd
#9 PostAuthor: garyd » Mon Oct 22, 2018 8:13 am
Pm your addy Foz and i'll get them in the post
FOZ1A
#10 PostAuthor: FOZ1A » Mon Oct 22, 2018 9:21 am
Gary, are you still in chertsey?
Foz
garyd
#11 PostAuthor: garyd » Mon Oct 22, 2018 10:19 am
Yup. still there :)
FOZ1A
#12 PostAuthor: FOZ1A » Mon Oct 22, 2018 12:03 pm
Are you around this week?
Foz
garyd
#13 PostAuthor: garyd » Mon Oct 22, 2018 1:07 pm
Most of the time...half term hols :)
Just out on accasions but should be able to open up Cafe du Gary when needed.
bunnysZ
Granny Magnet
#14 PostAuthor: bunnysZ » Mon Oct 22, 2018 3:20 pm
can I take the rear wheel adjusters please if still available. cheers
garyd
#15 PostAuthor: garyd » Mon Oct 22, 2018 4:46 pm
bunnysZ wrote:can I take the rear wheel adjusters please if still available. cheers
Yours...PMed you back :)
Return to “For Sale”
