More junk, er parts fore sale i mean....
Advertise your BIKES and PARTS here
Zomerset Zed
#1 PostAuthor: Zomerset Zed » Mon Apr 30, 2018 4:48 pm
Z1000 side panels:
These are pattern parts moulded in black self-coloured ABS. They have 3 x screw holes rather than the standard cast pegs, but they do fit the standard Z1000 (not Z1 or Z900) frame. Will need a good clean up. £30 ono
Original sprocket cover......er cover: SOLD
Slight scratch and £10 ono
Standard Z1000 cam chain tensioner:
Needs a good clean. £15 ono.
Bottom and front engine mounting plates and rear engine mount spacers. Rear plates have gone to a good home already: SOLD
£10 for lot or make me an offer for what you want.
Rear brake pedal: SOLD
Has been repaired at some point in its life, but fitted and worked ok off the original bike. £15 as its quite heavy to post.
Re: More junk, er parts fore sale i mean....
#2 PostAuthor: deka » Mon Apr 30, 2018 7:07 pm
Pm on its way
hartyb
#3 PostAuthor: hartyb » Mon Apr 30, 2018 9:01 pm
can i have the oil cover please
and whats the brake pedal off ? if its good for a Z1r or Mk2 I will have that as well
engine plats and spacers as well
Z1300 A1,
ZZR1100 Purple and orange
KE175b, KE175F
Zomerset Zed
#4 PostAuthor: Zomerset Zed » Mon Apr 30, 2018 9:36 pm
It was on an A2 model. I think Z1r should be ok, not sure about mk2. Maybe someone else can advise please?
I'll send you a PM if/when we can find out.
#5 PostAuthor: deka » Tue May 01, 2018 8:30 am
the original sprocket cover is a clutch adjuster inspection cover been looking for one for a while and got one on fleabay yesterday :sad
Zomerset Zed
#6 PostAuthor: Zomerset Zed » Tue May 01, 2018 8:43 am
Yes, but did it have the all-important gear lever inflicted scratch??
#7 PostAuthor: deka » Tue May 01, 2018 10:17 am
lol no it does not, I keep checking in case anyone had one and its just my luck to have pushed buy it now, any feedback on the pm i sent you
#8 PostAuthor: deka » Wed May 02, 2018 8:25 am
Hi Zomer
i sent you a pm on monday morning re the engine brackets is there any update?
derek
Zomerset Zed
#9 PostAuthor: Zomerset Zed » Thu May 03, 2018 8:24 am
I have a pm from you about the battery box but nothing mentioning the engine brackets. Harty B has said he wants them so you'll have to hang fire and if he changes his mind you can have them, ok?
#10 PostAuthor: deka » Thu May 03, 2018 9:18 am
My Apologies i wrote will pm on here and then followed it up with a actual pm but did not send :shock:
I had said i was intetrested in the the smaller of the two brackets (which i believe is the lower middle) and made an offer i should have said it on here :oops: :oops:
#11 PostAuthor: deka » Thu May 03, 2018 12:54 pm
managed to get sorted from one of the other guys, apologies again for the confusion
Zomerset Zed
#12 PostAuthor: Zomerset Zed » Sat Jul 28, 2018 4:40 pm
Going on ebay
Mr Puffin
#13 PostAuthor: Mr Puffin » Sat Aug 18, 2018 9:00 am
Are the sidecovers sold
Return to “For Sale”
