Steering damper J and maybe R maybe 1100B's Now sold
Advertise your BIKES and PARTS here
#1 PostAuthor: Al » Sat Jul 22, 2017 4:27 pm
Think this is the same as the ones ZPower sell for £62 http://www.z-power.co.uk/steering-damper-oe-type but this is much older.
A little scruffy but fully functioning and adjustable.
It includes the brackets (they look like a properly made aftermarket kit) which you dont get from ZP and these are for 38mm forks and the two captive nuts on the J frame, i believe the R variants and possibly the 1100B's please check youre nuts when its safe to do so :D
£35 not including post sound fair?
martinz1000r
Re: Steering damper J and maybe R maybe 1100B's
#2 PostAuthor: martinz1000r » Sun Jul 23, 2017 8:48 am
Al, i'll most likely have that off you. Can i just check the measurement of the damper first though? I bought one recently from DTR and it proved to short in terms of range of extension for my ELR. Don't want to end up with 2 the same. Will give you a call to sort out.
#3 PostAuthor: Al » Sun Jul 23, 2017 9:39 am
From the damper adjuster rotating knob to the centre of the eye on the moving end is 10 inches
The sweep of the damper rod is 3 and 3/4 inches.
This was on the bike when i bought it and the bracket that clamps to the fork leg was angled to be under the bottom yolk. Cross handed style to maximise the damping effect with the least amount of travel. The damper adjuster knob comes very close to the cam cover if i remember correctly and it was a faff to get it to arc without touching. Should have just left it alone as it worked fine as the PO had it set.
martinz1000r
#4 PostAuthor: martinz1000r » Sun Jul 23, 2017 10:09 am
That'll work. Same size as mine but the mounting brackets supplied by DTR are very different hence not right for the ELR.
Call you shortly to sort.
Return to “For Sale”
Users browsing this forum: No registered users and 97 guests
