uk master cylinder
uk master cylinder
Does the plastic bit of the uk Z1 master cylinder come out, sending it to get anodized. Cant see anything holing it in but will it hell as shift.
Harri.
There is a plastic base in the bottom. Use a right angled pick to pull upwards through one of the spaces and it will come out.
Under that are 2 screws which when undone will allow the plastic tube to be pulled out.
When you are ready for a new o ring let me know as I can supply you one foc
wilsonsjw11
z1bman wrote:you have a spring clip which secures the rubber gaiter which can be removed with a small electrical screwdriver then you have the cir clip which secures the piston & there is no need to depress the piston
Did just this today, needed a long thing circlip remover, and yes I had to depress the plunger to get the remover arms in, but did it. Bitch of a job
Users browsing this forum: No registered users and 91 guests
