paint removal from plastic
mick znone
#1 PostAuthor: mick znone » Fri May 13, 2016 3:59 pm
is there a good way to get paint off plastic parts, i have a plastic mudguard that has been painted and i want to strip it back but keep the finish of the plastic if i can.
#2 PostAuthor: kev edwards » Fri May 13, 2016 4:25 pm
Use a blow torch Mick! you know you want to, :o
mick znone
#3 PostAuthor: mick znone » Fri May 13, 2016 4:32 pm
kev edwards wrote:Use a blow torch Mick! you know you want to, :o
https://youtu.be/qJepFc93rOs
#4 PostAuthor: Garry.L » Fri May 13, 2016 4:52 pm
If the original part was keyed correctly before paint then you're only real option is to try wet & dry sanding with something like 1200 grit, lots of soap and water, then take it VERY easy.
mick znone
#5 PostAuthor: mick znone » Fri May 13, 2016 5:37 pm
im after the original plastic as the finish, no wish to repaint. just some moron has painted something clean the same colour as the plastic and now its chipping and peeling.
mick znone
#6 PostAuthor: mick znone » Fri May 13, 2016 5:40 pm
and no keying was done because lucky to me he was a moron and i can see the shiny clean finish where it has peeled. I can try lightly tapping it all loose but you never know what has been done by some on here, blows me away.
A1John
#7 PostAuthor: A1John » Fri May 13, 2016 5:42 pm
Use brake fluid its slow but it works and does not effect the plastic.
#8 PostAuthor: z1bman » Fri May 13, 2016 6:21 pm
cover it in gaffer tape & put it in the freezer the plastic will contract loosening the paint & should come of when you remove the tape
mick znone
#9 PostAuthor: mick znone » Fri May 13, 2016 6:30 pm
two options both possible for me, thanks guys i will move forward :up
#10 PostAuthor: ZedHead » Sat May 14, 2016 8:56 am
get ir soft bead blasted - simples
mick znone
#11 PostAuthor: mick znone » Sat May 14, 2016 8:59 am
ZedHead wrote:get ir soft bead blasted - simples
# but wouldnt that leave the shiny plastic with a dull finish :?:
#12 PostAuthor: ZedHead » Sat May 14, 2016 9:29 am
Maybe your tight
mick znone
#13 PostAuthor: mick znone » Sat May 14, 2016 11:50 am
ive always been tight but i gather you mean right but then you may mean tight :lol:
jez1100r
#14 PostAuthor: jez1100r » Sat May 14, 2016 8:57 pm
Blow it off with air line .fix a length of brake pipe to a blow gun you will get very hi pressure . If you have acsess to a compresser
mick znone
#15 PostAuthor: mick znone » Sat May 14, 2016 9:04 pm
thanks Jez, a compressor is a piece of kit i havnt looked into as yet, been thinking of one though. :fou
