Z1000K ltd or CSR 1000 swingarm pivot width
stevie g
#1 PostAuthor: stevie g » Wed Nov 18, 2015 9:18 pm
Hi Guys, as the subject says, can someone tell me the width at the pivot end of the swingarm please. I make it 250 mm but it's pretty hard to get a proper reading as the bike is complete. I've got a stretched deep brace swinger off my old Z1000 A1 which I know is 235 mm and was thinking of fitting it. Thanks to all replies.
stephen g mackay
skid11
#2 PostAuthor: skid11 » Thu Nov 19, 2015 10:24 am
Just checked and I make it 250 mm as well
stevie g
#3 PostAuthor: stevie g » Thu Nov 19, 2015 6:27 pm
OK thanks. Also just noticed the LTD swinger must be longer overall too cos my stretched one is nearly the same size as it.
stephen g mackay
Redbeard
#4 PostAuthor: Redbeard » Thu Nov 19, 2015 7:14 pm
That's odd, I am sure I fitted a 235mm wide dresda on my k model ltd and it went in spot on. The dresda was shorter though, I had to get a shorter chain.
1979 Z1000ST
stevie g
#5 PostAuthor: stevie g » Thu Nov 19, 2015 10:08 pm
Mmmm, now I'm confused. I'll double check tomorrow. Was it definitely a K model ? The B models were a different frame weren't they ?
stephen g mackay
Redbeard
#6 PostAuthor: Redbeard » Fri Nov 20, 2015 6:01 pm
Hi stevie, 100% a k model. I will find the project thread and give you the link.
1979 Z1000ST
stevie g
#7 PostAuthor: stevie g » Fri Nov 20, 2015 7:21 pm
OK thanks Redbeard, Yea I googled it and every forum says 235 mm. Cannot figure it out. I'm changing over the wheels in next day or two, (CSR wire to LTD mags) so I can refurb them. I'll be able to get a proper reading while the rear is off.
stephen g mackay
Redbeard
#8 PostAuthor: Redbeard » Fri Nov 20, 2015 8:04 pm
1979 Z1000ST
stevie g
#9 PostAuthor: stevie g » Fri Nov 20, 2015 8:56 pm
That's nce. Yep same as the CSR, leading front axle etc. I cannot post pics. I fitted a z thou tailpiece and a seat from I don't know what. Mine is a winter hack so nowhere near as clean as yours. If you go onto Facebook and type in S.T.A.B uk go into their photo's, the 5th pic is mine. With the crash helmet on the mirror.
stephen g mackay
stevie g
#10 PostAuthor: stevie g » Sat Nov 21, 2015 9:34 pm
You were correct Redbeard. I pulled the swinger out tonight and it is 235 mm. So that's great news for my Metmachex I'll be fitting. Thanks bud, appreciate it.
stephen g mackay
Redbeard
#11 PostAuthor: Redbeard » Sun Nov 22, 2015 8:07 am
That's good news Stevie, glad to help. Oh I don't have a fbook account so can't view your bike. Post some pics on here when you're done mate, be good to see.
1979 Z1000ST
mick znone
#12 PostAuthor: mick znone » Sun Nov 22, 2015 9:00 am
Redbeard
#13 PostAuthor: Redbeard » Sun Nov 22, 2015 9:04 am
Thanks Mick :wink: Bike looks much better stevie with the tail on it.
1979 Z1000ST
stevie g
#14 PostAuthor: stevie g » Sun Nov 22, 2015 11:54 am
Thanks Mick, yep that's my old girl :D Should look quite nice with the mag wheels fitted. Thanks again guys for your help. $
stephen g mackay
stevie g
#15 PostAuthor: stevie g » Sun Nov 22, 2015 12:03 pm
What fairing is that you have fitted on your LTD redbeard ? I like it and may just get one.
stephen g mackay
