Swing arm info
Chris Riv
Swing arm info
#1 PostAuthor: Chris Riv » Wed Aug 19, 2015 6:52 am
Lads, I'm looking for info on swing arms for my latest Z1 project. I need an ally swing arm, as near to the original length (or maybe slightly longer) & pivot width as possible. Shock mounts are not an issue as I can make them. I'll be fitting a wide wheel as well.
Who has fitted what to their projects? What mods have you done to make fitting possible? Any info gratefully received.
Cheers, Chris. :D
Viktor Larsson
#2 PostAuthor: Viktor Larsson » Wed Aug 19, 2015 7:51 am
The ZRX1100 swingarm is almost a straight fit as I recall. You can find info in my build thread on what was needed to make it fit. Can run a 180 rear wheel too.
There's no replacement for displacement.
Chris Riv
#3 PostAuthor: Chris Riv » Sun Aug 23, 2015 10:20 pm
Many thanks Viktor.
#4 PostAuthor: Ginger Bear » Mon Aug 24, 2015 6:24 am
Chris,
Most Suzuki stuff will more or less go straight in. I favour GSXR600 SRAD. Fitted to all of these;
Even got one on me current Z900 project. :D
Rear footrest mounts may need to be sacrificed. :??
# 104
tlc
#5 PostAuthor: tlc » Mon Aug 24, 2015 7:15 am
Chris.
I'm gonna recommend the Yammy XJR swinger. It will take wider wheels easily, is 1" longer than the Zed and has twin shock mounts already fitted. These mean either you space out your top mounts to suit or move in the bottom ones if you need.
It needs about 6mm shaving from each side of the pivot to suit the Zed frame and a sleeve to marry the standard Zed spindle to the XJR bearing sleeve.
Rear axle size is good too for using Zed hubs.
Users browsing this forum: No registered users and 125 guests
