Ultrasonic carb cleaning solution
Can anyone recomend a cleaning solution / liquid to use in my newly acquired ultrasonic cleaner for cleaning carbs.
I have had some mixed results so far.
Cheers Dave
Cheers Dave
I have tried numerous cocktails over the years and settled on just plain hot water.
My cleaner has a built in heater but have found it more efficient to just boil the kettle and pour it in.
The trick is not to use the ultrasonic as the only cleaning method but as one of the final stages in cleaning operations in addition to the normal degrease, solvent wash and air line.
- steve bowdler
I sell a great tfr I buy it in concentrate then break it down to a 10-1 solution kind to all pressure washing equipment, I used this in my little ultrasonic cleaner with great success on my floatbowls and jets then blew them out with a compressor before dry, for things that don't come out, my thou RX has atmospheric snorkels, you know, no overflows! faster you go, forces more air into carbs, there are very tiny inset jets which don't come out so carb cleaner and compressor oh and magniyfing glass coz they're so bloody small, but are crucial to starting, but don't get it in your eyes coz carb cleaner stings, oh it buggers plastic manifiying stuff too.
More Smiles Per Mile
Thanks so far guyz. Using straight paraffin at about 60 degrees c at the moment but not too impressed..
I can see IPA would be an effective degreaser even without ultrasonics.
Whats tfr ? Gpjes.
Keep suggestions coming peeps, very interesting.
Oh tried a weak solution of soap powder and tap water. After a 15 minute dip in the U.Sonic tank the carb surface started to oxidise!!!!! ie white deposits starting to form...hence the move to paraffin.
Cheers Dave
Whats tfr ? Gpjes.
Cheers Dave
Don't use any flammable liquids it's very dodgy practice.
The white deposits are from the wash powder, not oxidization.
I've been through all the possible solvents, soaps and de-greasers and found just plain water to be most effective.
No point sticking in greasy/oily items in as soft deposits just absorb the cavitation and it won't shift.
Best to manually degrease with a brush and petrol etc before putting in the tank.
I've had good results with this stuff;
http://mistralie.co.uk/collections/ultr ... hine-parts
I would also agree it's important to degrease the carbs first.
Ginger Bear wrote:I've had good results with this stuff;
+1 s'what I use too.
Will buy some and give it a go.
- Z903
Check this little gadget...
http://www.youtube.com/watch?v=R1DtY2VwSyY
