ZRX Carbs on a GPz Head
LTD Project
#1 PostAuthor: LTD Project » Fri Jun 20, 2014 4:26 am
Quick question I hope. Will ZRX Carbs fit on a GPz1100 B1/2 head? Getting to my wits end with the BS34s on at present.
KZ1000 B4 under light restoration.
big green bus
#2 PostAuthor: big green bus » Sun Jun 22, 2014 8:22 am
Go and see John Warrington in Malton, get him to dyno it, it was the thing I ever did He will sort the carb probs with the 34's
garyd
#3 PostAuthor: garyd » Sun Jun 22, 2014 2:23 pm
Can recommend John...known him for some time and really enjoys his work.
He'll make sure your bike runs right.
LTD Project
#4 PostAuthor: LTD Project » Sun Jun 22, 2014 3:48 pm
Ok thanks, Malton not too far if I can get it running well enough to get it over there!
No answers from anyone on the original question. Any takers?
garyd
#5 PostAuthor: garyd » Sun Jun 22, 2014 7:01 pm
My first thought would be that they are not spaced the same....as watercooled engines are normally closer together for the bores.
harrythemagnum
#6 PostAuthor: harrythemagnum » Sun Jun 22, 2014 7:25 pm
No, wont fit, spacing is wrong, ZRX camchain is on the end of the engine.
:wink:
What a wonderful philosophy you have,
LTD Project
#7 PostAuthor: LTD Project » Sun Jun 22, 2014 7:36 pm
Ok great, thanks for the responses. Will try. A bit more with the 34s then it might be time for some spicy new carbs.... Mikuni or Keihin?
