Fuel Tank inside treatment flaked off
Any tips on how to prevent more of that rust proofing treatment
peeling off inside the tank?
Recently had fuel starvation problems and suspected it was due to that
stuff that is used to line the inside of tanks to prevent corrosion, drained the
fuel and sure enough, the gauze filter on the petcock was bunged up
with the darn stuff.
I'll take the tank over to a friends to get it blown through with an airline,
anyone know of anything that can shift the lining treatment before I refit
the tank and refill with fuel again?
I tried that stuff and it does remove most of the sealant took a couple of times to do the trick though,cellulose thinners can work but needs care with tank paint...
remover
go online,to rustbusters,,,theres some stuff called as10,,it removes it all,dont get any on the paint itl remove that as well,then clean out the tank then re seal..
- Flying Tiger
As already reccomended by Paul the TCP stuff is brilliant. It is an involved process, but follow the instructions exactly and it will come out great. Just be wary the tank may have been sealed the first time round because of a fuel leak? Corrosion/pinholes?
Flying Tiger Paintwork - www.facebook.com/FlyingTigerPaintwork - flyingtigerpaintwork@hotmail.co.uk - 07796693751
Jay1969 wrote:
I'm not going to re-seal my tank, but I appreciate your help
z1bman, thanks
it has been sealed for a reason if you don't seal it you will have constant problems with the carbs flooding or the bike not running properly. even bikes with minimal rust it will find its way through as many filters as you can put on it. seal it & no more problems
If you are confident your tank is structurally sound, you can get the inside bead blasted. "Oh no!!!"
yes! you can.
Not sure how much it would cost but cant cost that much. I've done several myself and it's like a new tank afterwards - obviously you keep the pressure down to a minimum.
Mask off the exterior meticulously, then cover with gaffer tape. when all the rust is out there is no problem with the media, it blows out easily and a few rinses with petrol, poured into a coffee filter will confirm it's clean. good as new.
I attach a length of aquarium tube to my blasting tube, taped to a stiff bit of fence wire so I can direct it inside the tank. Fix the ceramic nozzle in the end of the aquarium tube. very effective. I use fine glass bead.
yes! you can.
malmojoe wrote:If you are confident your tank is structurally sound, you can get the inside bead blasted. "Oh no!!!"
yes! you can.
How much would you charge for this service, or do only service your
own tanks?
Users browsing this forum: No registered users and 94 guests
