Project
pignog
Project
#1 PostAuthor: pignog » Thu Apr 18, 2013 4:07 pm
Thinking of adding a 400 zxr front forks, discs, wheel and calipers.
And a 400 zxr rear wheel,disc & caliper to a gsx1100 swinging arm at the rear.
Any thoughts, problems??
Also any gsx swinging arms available ??
I want to keep the twin shock look.
steve.w
#2 PostAuthor: steve.w » Thu Apr 18, 2013 4:11 pm
i have a gsx 1100 et one ..the ally one same one fitted to a kat
#3 PostAuthor: Pigford » Thu Apr 18, 2013 5:32 pm
Slingshot (GSX-R1100) swinger .............
#4 PostAuthor: zed1015 » Thu Apr 18, 2013 6:10 pm
zxr400 forks are too short, you will be dragging your exhaust on the ground unless you are fitting stepped yokes to compensate.
Even zxr750 forks will make the bike sit very low.
Jacking the back end up as some do to restore some ground clearance will create a tankslapping deathtrap at 100mph+.
ZX9R-B forks are the ones to go for.
pignog
#5 PostAuthor: pignog » Fri Apr 19, 2013 6:48 am
Thanks for the info re ZXR400 forks, I'll look for 900 forks then. I'm glad I asked. :D
Users browsing this forum: ludders and 110 guests
