GB's 'Period' modded Z1000A2 with 'Toast Racks'
KeithZ1R
#91 PostAuthor: KeithZ1R » Thu Oct 11, 2012 2:27 pm
Cheers Steve but Ive allready got small ratchet straps just would never have come up with that idea, :idea: its now logged for the next time :D
Keith
:bop :gom
mistaken.
Phil Churchett winner 2013
#92 PostAuthor: Ginger Bear » Thu Oct 11, 2012 5:45 pm
Been busy today, sorting out a couple of the 'less glamorous' jobs.
First off was to re-fit the generator windings, but more importantly seal the pesky rubber grommet.
The method I use was 'gleaned' from this very website & has worked every time........ So far. :roll:
First step is to get it all spotlessly clean. The grommet, & casing benefit from being 'keyed' with a bit of emery paper or something similar.
Next is to apply some sealant. Threebond 1211 was recommended (on here). Other stuff may well work, but this stuff works for me.
Pull the sealant coated wires through the grommet, whilst sliding it into the casing.
I have temporarily fitted the casing, to keep the grommet in place, whilst the sealant goes off. I have put a little bit of polythene between the grommet & engine cases, to stop it all sticking together. I would have fitted it permanently, but I'm still waiting for a new starter ring damper to arrive. :roll:
# 104
#93 PostAuthor: Ginger Bear » Thu Oct 11, 2012 5:52 pm
Next job was to tackle the loom..... Another dirty shitty mess. :roll:
After a couple of hours with a can of brake cleaner, a lot of the grime was removed.
Most of the old tape was removed, and replaced with some new. I have fitted some new connectors where needed & replaced the insulation sleeves on a lot of others.
Went from this;
to this:
# 104
coldsummer
#94 PostAuthor: coldsummer » Thu Oct 11, 2012 6:13 pm
Ah Brake Cleaner, the mechanic's magic fairy dust :D
sanderz
#95 PostAuthor: sanderz » Sun Oct 14, 2012 9:04 am
Coming together nicely there GB (and quickly) - those shockers look mint :up
Good tip on the alternater bung, valuable info - i bolted a flat plate to the casing while the sealant went 'off'
Interesting site that Skiffy for odds and sods, nice one!
http://www.skiffy.com/docs/menufr.cfm?t ... gindex.cfm
Keep it going.
Wots up DOHC
#96 PostAuthor: Ginger Bear » Mon Oct 15, 2012 12:37 pm
'Stickered up' shocks
Many thanks for those Vic. :wink:
# 104
RALPHARAMA
#97 PostAuthor: RALPHARAMA » Mon Oct 15, 2012 6:33 pm
Those shox look shit hot! I've never seen them with chromed bodies before! Real nice rebuild :D
Ralph Ferrand
Is Vic There
#98 PostAuthor: Is Vic There » Mon Oct 15, 2012 8:06 pm
Ginger Bear wrote:'Stickered up' shocks
Glad you got them, they do look good. The bloke who makes them has joined the site as well, he's doing up a Z650. Wonder what else he does?
Vic
ollie
#99 PostAuthor: ollie » Tue Oct 16, 2012 3:27 pm
shocks look superb steve as does the frame ,i have same make shocks but plastic coated resevoir bodies ,not seen the chrome ones before :wink: cant wait for next installment :)
#100 PostAuthor: Ginger Bear » Tue Oct 16, 2012 6:36 pm
Thank's boy's for the encouragement. :up
After some deliberation on what to do about cylinder head nuts, the one's I had ordered turned up today. :D
http://www.z1ownersclub.co.uk/forum/vie ... hp?t=22202
So there was no excuse not to fit the head.
Since the motor is completely dry, I pumped a whole can of my 'free' oil into the oilways, I don't know if it will make a lot of difference on the initial start up, but it can't do any harm.
Head on, cams fitted & all timed up. I'll re-check the valve clearances on my next visit. Then I can fit me Toast Racks! :lon :lon
# 104
mikey
#101 PostAuthor: mikey » Tue Oct 16, 2012 7:14 pm
Looking good steve glad to see your keeping your greasy mits off the bright work :lol:
ollie
#102 PostAuthor: ollie » Tue Oct 16, 2012 9:06 pm
wow that motor looks like new now,a great transformation !!! ,and love those chunky rear engine mounts :wink: keep up the great work steve :beer
#103 PostAuthor: Ginger Bear » Sat Oct 27, 2012 6:15 pm
Not managed to progress much in the last week, been busy with Stafford & work.
Can't say the same for Mikey though, I picked up this 'box of bling' a couple of days ago.
Contents include wheel's with polished rims & spokes. I'll be painting these at a later stage, Fork bottoms, will be rebuilt once I get the stantions back from re-chroming. Last but not least is a highly polished, finned points cover. :sou
Electrics are coming on quite nicely....
And finally for today, I fitted me........................................
...................................................... Toast Racks!!! :lon :aha :lan
# 104
mikey
#104 PostAuthor: mikey » Sat Oct 27, 2012 9:18 pm
Looking good steve toast racks and all :D
RALPHARAMA
#105 PostAuthor: RALPHARAMA » Sun Oct 28, 2012 7:20 pm
Looking good apollo :D
Ralph Ferrand
