Hi, it looks like I have lost the key to my GPZ900 does anybody know of someone who would be able to make a replacemnet key from the ignition barrel.
Cheers Rob
Lost key
the lock usually has a three digit number on it which is the key code. You should be able to get a key using it e.g.
http://www.key-men.com/shopping/show_ca ... d=Kawasaki
or your local Kwak shop
if you can remove the ignition switch the key number is stamped on the flat side of the front of the switch in small numbers key number will start with a z followed by 4 numbers example Z5674.
this company has all the major key codes just give them your key no if you can find it
Ashfield Security
160a High Street
Blackheath
West Midlands
B65 0DX
TEL: 0121 561 3332
Ashfield Security
160a High Street
Blackheath
West Midlands
B65 0DX
TEL: 0121 561 3332
the numbers are on the aluminium casing part of the switch but are really small you would be advised to use a magnifying glass to read them there are no numbers on the tumblers. have a look at the metal plate by the steering lock on the switch. if your key is the same as the seat lock remove the l/h side panel + remove the lock the key no is also stamped on the lock
Found the numbers, had to give the switch a good clean, the number is z 5@@@
does this sound right. There is another set of numbers below the steering lock. Today was such a bore all that time on set with Ellie and my crew. I am expecting the offers to come flooding in. Golden globe next!Many thanks for your help I owe you a beer,
Regards Rob
Regards Rob
Z1100R, RD 125LC, Zx7r , Endurance racer, KTM 990rcr
Users browsing this forum: Robw and 111 guests
