Tips For Bending Rear Sprocket Tab Washers Please??
pertonpc
#1 PostAuthor: pertonpc » Sun Jan 15, 2012 10:01 am
Hi Folks,
I've got three new tab washers and a re-zinced rear sprocket and nuts going together. The nuts are ready for torquing down but I don't want to end up with chisel/ pry marks on the new zinc coating....
Any tips for how you bend up the three 2 holed tab washers on rear sprocket without damaging the finish on sprocket underneath please?
Needs to look like this at the end.
Was thinking about sticking a small flat thing under edge of tab before the nut is torqued down - so I can start to raise it without chiseling under the tab and marking the sprocket. Once it is raised a few mill I was going to use pair of angled grips with tape over the jaws to squeeze it onto the nut.
Any ideas / techniques would be appreciated. Ta from Mark
#2 PostAuthor: z1bman » Sun Jan 15, 2012 10:29 am
hi mark i usually gently lever up the edge of the tab washer with a wood chisel then use a pair of adjustable pipe wrenches to secure the washer against the nut
regards paul
wilsonsjw11
#3 PostAuthor: wilsonsjw11 » Sun Jan 15, 2012 10:33 am
Mark
Bend a small lip on the 2 edges that are to be folded up with a pair of pliers and a rag before you put the bolts through them, then once torqued up tap them over with a piece of brass flat bar as a chisel/drift.
Regards
Steve
ade woollams
#4 PostAuthor: ade woollams » Sun Jan 15, 2012 1:09 pm
jack hammer and crow bar .the harley way
pertonpc
#5 PostAuthor: pertonpc » Sun Jan 15, 2012 3:30 pm
Thanks fellas,
I pre-marked the angles to bend on the washers and started the bend before fitting. Gaffa tape on tip of chisel and grips and job's a good un.
Don't think I have damaged the zinc finish any where.
Even managed to make those little triangle shapes pointing out towards the rim like the factory fellas did.
Thanks again from Mark :D
#6 PostAuthor: Rich » Sun Jan 15, 2012 6:46 pm
make yourself a nylon "chisel" for the next time.
#7 PostAuthor: PAULJAC47 » Sun Jan 15, 2012 7:41 pm
Is this a "wind up"???? :shock:
Garn 1
#8 PostAuthor: Garn 1 » Sun Jan 15, 2012 8:30 pm
Mark, I have four items to add to your methods... Some already mentioned.
1. Use stainless steel tab-washers & nuts (departing from standard, but look's great).
2. Pre-bend tab-washers in soft-jaw vice, just one side. I have seen your double side .. angled towards rim, however, I'm not sure if it was common.. Could be wrong on this!
3. Use brass punch/ chisel to flatten one edge of both ends of the tab-washer. Your Gaffa-tape idea is good!
4 *** Use a small amount of anti-scuffing paste under each nut to avoid twisting/ bending the tab-washer when torquing up.
I have laboured over this task often.
KeithZ1R
#9 PostAuthor: KeithZ1R » Sun Jan 15, 2012 8:43 pm
PAULJAC47 wrote:Is this a "wind up"???? :shock:
don't look like it Paul :) different strokes an all that :)
Keith
:bop :gom
mistaken.
Phil Churchett winner 2013
pertonpc
#10 PostAuthor: pertonpc » Sun Jan 15, 2012 8:46 pm
Thanks Garn
Your input is always wise.
I went for the double bend because my own bike was on original chain & sprox and had it as standard, the Kawa 650 Service Manual and owners hand book show it in the example pics, and original 650 sales brochure pics I have seen all show the double bend triangle shape - so I think it was fairly common from the factory on those bikes.
Appreciate you can dispense with them if you use locking nuts etc. but I wanted to try and get a factory standard look.
I had never heard of anti scuffing paste - that's something else you have taught me - what is the brand name for that product?
Cheers from Mark
KeithZ1R
#11 PostAuthor: KeithZ1R » Sun Jan 15, 2012 9:04 pm
pertonpc wrote:Thanks Garn
Cheers from Mark
Rocol :)
Keith
:bop :gom
mistaken.
stephen parr
#12 PostAuthor: stephen parr » Sun Jan 15, 2012 9:15 pm
You crease me up you do Paul :!: :lool
pertonpc
#13 PostAuthor: pertonpc » Sun Jan 15, 2012 9:18 pm
Thanks for that Keith,
not seen their products round here - will keep my eyes open.
Z1parR
#14 PostAuthor: Z1parR » Sun Jan 15, 2012 9:39 pm
Here you are Mark , new tin design on the right , i added the plug box for comparison .
Its very good stuff but the price is er sobering :shock:
0172 . Geoff Parr
buzzard
tab washers
#15 PostAuthor: buzzard » Sun Jan 15, 2012 10:54 pm
ditch the tab washers, use a flat washer, then apply a medium to high strength Loctite(usually a green colour) thats what I'd do. BUZZARD
Every man should have a shed (for bikes obviously..)
