finally got my holy grail...n.z.r
kas750
#31 PostAuthor: kas750 » Fri Feb 26, 2010 6:09 pm
done a little more
Rolling chassis now
irhobotolo
#32 PostAuthor: irhobotolo » Fri Feb 26, 2010 6:38 pm
kas750 wrote: and i have also put the rear shockers back together
Is it easy to take old rear shocks to bits and reasemble them ? Whats the procedure as manuals always seem to say that they are sealed units.
tlc
#33 PostAuthor: tlc » Fri Feb 26, 2010 7:04 pm
Check out MaineKz `73 resto.
He covers all you need to know !
kas750
#34 PostAuthor: kas750 » Fri Feb 26, 2010 7:16 pm
Yes it's fairly easy to split the shocks.I had to make a coil spring clamp using some threaded bar and 25mm angle iron.I compressed the springs with the compressor then drove the roll pin out of the top mount.There is then a lock nut that locks the damper rod to the top mount.Unscrew these and then it all comes apart.All this assumes that you have shocks without the shrouds.In that case i assume that you would have to be more inventive with the clamping arrangement.
kas750
#35 PostAuthor: kas750 » Fri Feb 26, 2010 7:38 pm
Rained off this afternoon,so heres todays efforts.
tlc
#36 PostAuthor: tlc » Fri Feb 26, 2010 7:43 pm
Superb !
I`m enjoying this :D
jimmock
#37 PostAuthor: jimmock » Fri Feb 26, 2010 7:49 pm
Looks like a mega rebuild Kas.
I noticed your Boxford lathe (CUD I think??)
Like Davy I noticed the Banner that was banned!!
Jimmock.
Jimmock. :wnkr
I hate people I don't like !
kas750
#38 PostAuthor: kas750 » Fri Feb 26, 2010 7:57 pm
Thanks for the kind words chaps,its much appreciated.Btw Jim the lathe is a model b which is ideal for metric screw cutting,made in 1970.Its ex school so very light use,i have owned it about 10 years and gave 400 quid for it.
jimmock
#39 PostAuthor: jimmock » Fri Feb 26, 2010 8:28 pm
Kas I thought it was a C series as I couldn't see any levers for the powered crossfeed??
There is other items blocking the view.
Jimmock.
Jimmock. :wnkr
#40 PostAuthor: Pigford » Fri Feb 26, 2010 8:41 pm
Wooowww.... That looks a real sweet bike, already :wink:
kas750
#41 PostAuthor: kas750 » Tue Mar 09, 2010 9:31 pm
ok,a little more progress.Wiring loom fitted, as well as controls,turn signals,footrests and engine covers.
