tarozzi rearsets
Redbeard
tarozzi rearsets
#1 PostAuthor: Redbeard » Sun Jan 17, 2010 8:49 pm
Just been on the disco volante site, im after some rearsets for the ST. i know a few of you have them, but is it best to go for model specific or universal fitting ones? there's quite a price difference. if model specific, would the MK2 or J ones do the job as ST isn't listed. Mine is 1980. Thanks.
1979 Z1000ST
hanskloss
#2 PostAuthor: hanskloss » Tue Jan 19, 2010 11:44 am
I think universal fit ones might be bare levers and pegs, LESS hardware-you'll have to buy extra clevises, pins, rods whatever needed to fit your bike (can be seen on diagrams) best calculate the cost of extra bits needed, I got myself a model specific folding set for Z900 and it was straight fit
Redbeard
#3 PostAuthor: Redbeard » Tue Jan 19, 2010 6:37 pm
Thats great, all i needed to know. Thanks mate. :wink:
1979 Z1000ST
scott
Junior Section leader
#4 PostAuthor: scott » Wed Jan 20, 2010 8:25 am
I bought a set specific to my z1000a2 but they needed a tweek here and there.....happy with them now though although they are not the prettiest looking rearsets are they?
Redbeard
#5 PostAuthor: Redbeard » Wed Jan 20, 2010 7:07 pm
Any idea if they will interfere with the kickstart?
1979 Z1000ST
hanskloss
#6 PostAuthor: hanskloss » Wed Jan 20, 2010 8:56 pm
it does interfere slightly, let's say the kickstart travel is 180 degrees, at about 150 it hits the tarozzi's brake lever (it's soft and gets marked), nothing can fix this - have to live with it, I kick start ocassionally just to show off and to save the lever I do it with footpeg opened so about 90 degrees has to do, and it does fine
Redbeard
#7 PostAuthor: Redbeard » Wed Jan 20, 2010 9:46 pm
That sounds ok, i think 90-150 degrees is enough to fire up my bike with the kick start. i use it all the time so i think i'll get away with it. thanks mate.
1979 Z1000ST
Redbeard
#8 PostAuthor: Redbeard » Thu Jan 21, 2010 8:30 pm
They don't do ST specific ones, anyone know if the MK2 ones be close enough? I know there are subtle frame differences but anyone got a better idea? Some pics of mine if it helps...
1979 Z1000ST
hanskloss
#9 PostAuthor: hanskloss » Fri Jan 22, 2010 8:01 am
Redbeard, there is quite a difference, check RAASK website, they list MK2 and ST rearsets separately and they look way different, I had Raasks on my bike before and they worked OK but had rather agricultural look, ST back plates seem to be a bit nicer, at least you have an option if no joy with Tarozzis http://www.raask.se/ind-eng.htm (rearsets/pick model)
Redbeard
#10 PostAuthor: Redbeard » Fri Jan 22, 2010 7:33 pm
You're right, quite a difference between the 2. Your help is much appreciated, looks like raask may be the way to go for the ST. Thanks again!
1979 Z1000ST
