Hi,
I’m trying to start my Z1000A1, not got it to fire yet but its stop turning over. When I press the starter button theres a load “click” and nothing more, it has been turning over but has done this from time to time. Had the starter out a few times and stripped but can’t find much wrong. My question is - is it likely to be the starter motor or is the solenoid sticking do you think? I’ve also fully charge the battery and tried a jump starter on it……
Cheers Russ
Solenoid or Stater motor?
Z650C2, B1, F1, ZX9R, Z1000A1
- warren3200gt
Re: Solenoid or Stater motor?
Have you tried bypassing the solenoid by shorting across the two top terminals with a spanner/jump lead etc. If the starter turns over it's the solenoid, if it doesn't its the starter. Narrows it down.
Turns out its the starter, kick it over instead and success
running a bit rough but it ran
- warren3200gt
If you rebuilt the starter and over tightened the two long case screws it makes the planetary gears very tight and stops the starter turning. Also the planetary gearbox should be well greased with fresh grease.
Ah, ok, thanks, I’ll take it out again, thanks
- warren3200gt
Once you've checked it out, before reffiting you can put your foot on it and jup leads to check she spins up OK.
Users browsing this forum: Google [Bot] and 77 guests
